Trade: Custom Metal Fabrication/Residential Construction
Flux Core Wire
Any suggestions on what is one of the best flux core welding wires for my mig - I have 2, a hobart 187 and a miller 211. I was using hobart brand and it worked great, never a problem and nice welds. But my inventory is running low and its getting hard to track down since my regular internet supplier doesnt carry it anymore.
So what would you recommend in its place? Thanks |
Trade: Pretty much anything with wood
Re: Flux Core Wire
A bottle of gas and some mig wire. flux core
Re: Flux Core Wire
I agree with Morning Wood. Shield it with gas!
The Deck Guy
Re: Flux Core Wire
I don't weld that much, but I initially used Flux Core because I didn't have gas.
Now that I have gas, I won't go back to flux core wire. It's so much easier to weld with gas and the welds are much better. I have a Hobart 140.
Twisted Cameron
Trade: Concrete, Metal buildings
Re: Flux Core Wire
Don't listen to these guys, they are too used to building decks. I use flux core all the time on thin gauge outside work. IT DOES HAVE ITS PLACE!!!! Whats wrong with your local supplier? I am sure Hobart still makes flux core wire. Sometimes buying local does have its perks. Good luck!
Re: Flux Core Wire
Gas is great as long as there's no draft, but if you're working outside fluxcore or stick is the way to go. Unless you're in a tent. Lincoln wire is pretty popular should do a good job as a replacement wire.
Re: Flux Core Wire
Hey Im all for gas but I am not always in the shop welding. Any welder I have with gas sits in the shop only. I like doing a lot of builds and installations on site with flux core because all I need is my welder - no heavy tanks to lug around and the flux core allows me to have my welder in my back seat cargo bay of my truck nice and safe, fits perfectly.
Re: Flux Core Wire
In that case, I would buy local.
Re: Flux Core Wire
I understand the portability issue, but I lug my tank with my welder when I have to do a job away from the shop.
Take care, |
Re: Flux Core Wire
What do you do if there's a breeze going on when you're welding? Sometimes a mig weld will appear fine but when you skim it with a grinder it's loaded with porosity; this usually occurs when the shielding gas gets blown away from the weld pool.
Re: Flux Core Wire
I try my best to block any breezes that might affect the shield gas "cloud," usually with a tarp, plywood, etc.
Re: Flux Core Wire
I dont mind lugging a tank around either but that was when I could only afford 1 welder. When business started getting good I purposely bought more migs just for the reason of not bringing a tank with me. Dont have to worry about damaging any gas gauges, hose, and no need to bring a cart with me. Basically the fact that it fits nice and tight in its place I always have it with me even if it just a regular construction type job I can still weld steel quick and easy if needed - but I never use the flux core if its structural, only for ornamental iron
