Diesel Fuel Tank Repair - Welding & Steel Trades - Contractor Talk
Old 11-12-2016, 10:45 AM   #1
txgencon's Avatar
Rewards Points: 430
Before I embark on finding a shop to repair the fuel tank for my C7500, here is my question.
The tank sits on supports under the driver's door and has developed rust holes where it contacts the supports. I'm thinking the best fix would be to weld 4" wide flat (or would it be considered strap?) to reinforce the tank and eliminate the thin places in the tank. Good idea or not?
I know I need to thoroughly clean the inside of the tank and remove all remnants of diesel. What is the best solution (chemically) to neutralize the explosion hazard?
I used to think a lot of the people I encountered were stupid - then I realized how much I was overestimating them.
txgencon is offline
Old 11-12-2016, 10:56 AM   #2
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,726
Re: Diesel Fuel Tank Repair
For making BBQs we fill em with water.
Sent from my Nexus 6P using Tapatalk
Inner10 is online now
Old 11-12-2016, 03:25 PM   #3
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 2,268
Buy a used tank and slap it in. Less down time and probably the same cost.
As mentioned welding it requires filling with water, then it should be well dried after. The chances of it actually fitting back into place with more material is slim too.
Peter_C is offline
Old 11-12-2016, 08:31 PM   #4
Moxley-Kidwell's Avatar
Trade: Excavation & Asphalt Paving
Rewards Points: 286
We had a welder fix a couple spots on our lowboy alum. tanks. He had some scrap aluminum plate, mechanic dropped the tanks and emptied and guy welded them all one Saturday morning. Diesel isn't as bad as gas, empty and get as dry as you can maybe you can run a fan in it for a while to dry it out more. Only cost us a couple hundred bucks for the welder.
Moxley-Kidwell is offline
Old 11-12-2016, 08:38 PM   #5
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,016
Putting broken up dry ice in a tank displaces flammable vapor.
We Fix Houses is offline
Tank Coatings Bomnskie Sandblasting 4 02-09-2013 01:33 PM
Need to hire full time repair man/woman in phoenix arizona, now!! Phoenix8 Help Wanted or Looking For Work 24 05-16-2012 04:39 PM
Underground Diesel Tank Duff Plumbing 6 03-26-2008 10:39 PM
Wiring/grounding for diesel tank? jimb317 Electrical 3 10-20-2007 04:58 PM
Fuel Tank Condensation denick Excavation & Site Work 3 05-26-2006 08:29 PM
