Cutting Mig Gun Liner?
Old 10-19-2009, 08:35 PM   #1
Kastoria's Avatar
Trade: Custom Metal Fabrication/Residential Construction
What do you guys use to cut a new mig gun liner to length? I just slid in a new liner today and cant find anything to cut it with that will give me a nice clean cut...wire cutters were crap and just split the liner coil open but never really cut anything. Im thinking maybe a good pair of linesman pliers might have the strength but dont know. What do you suggest?
Kastoria is offline
Old 10-20-2009, 01:35 AM   #2
dirtydawg
App-ironworks's Avatar
Trade: Metal Fabricating/Welding/Ornamental Metal
Re: Cutting Mig Gun Liner?
I wouldn't recommend cutting with pliers, you may crush the end and cause feed problems. I'd try a band saw or porta band and if that's not available a 4-1/2" angle grinder and a cut off wheel. Go easy, then deburr the inside when you're done.
App-ironworks is online now
Old 10-20-2009, 02:06 AM   #3
Kastoria's Avatar
Yeah the grinder crossed my mind when the pliers didnt work on the old liner (as a test) but the grinder seemed like overkill...but it would work. Just thought there was some type of tool that would just snip that off. Ive never had to replace a liner in any of my mig welders, but I guess after all these years one of them was bound to give out. Thanks.
Kastoria is offline
Old 10-20-2009, 08:20 AM   #4
dirtydawg
You're lucky it seems like I have to replace liners every couple of years, times 3 migs welders equals 1 a year at least.
I just cruised your site, nice work.
Old 10-20-2009, 01:46 PM   #5
Resident Lurker
LJSMITH1's Avatar
Trade: Electrical Products Manufacturer
DREMEL with a abrasive cutting wheel..
Larry
LJSMITH1 is offline
Old 10-20-2009, 10:47 PM   #6
Kastoria's Avatar
Thats what Ive heard, everyone is always replacing liners all the time. Maybe mine needed it sooner but they always worked fine until now (wire wasnt feeding out the conductor tube). I hope this didnt start some trend now with my other welders, I have 3 migs too...I sure dont wanna have to do another liner. Its time consuming and a pain in the A** especially when it happens in the middle of a project.
Thanks for takin' a look at the the site
Hmmm.dremel..I like that idea.
Kastoria is offline
Old 10-21-2009, 10:55 AM   #7
dirtydawg
Well, it could be worse. At one place I used to work we had to swap liners for 6 welders pretty regularly till they laid off the moron who was driving over them with the forklift.
Old 10-22-2009, 08:24 PM   #8
Kastoria's Avatar
hahahaha
Kastoria is offline
Old 11-13-2009, 09:43 PM   #9
CaliWelder's Avatar
Trade: Welder, Maintenance Mechanic
hmm.. never had a problem choppin them with a good pair of Klein side cutters, i replaced 6 liners yesterday. A cutting wheel does seem like it would work good if your cutters are dull.
CaliWelder is offline
Old 11-13-2009, 11:25 PM   #10
Kastoria's Avatar
Just went a bought a pair of Knypex mini bolt cutters...work great.
Kastoria is offline
Old 07-25-2010, 11:50 AM   #11
Greenbuggy's Avatar
Trade: Sandblasting
I've never had a problem cutting the steel liners with a thin cutoff wheel on an air die grinder. The teflon/plastic style I've always just cut with a wire cutter.
Greenbuggy is offline
Old 07-25-2010, 03:11 PM   #12
jayincville's Avatar
Trade: HVAC
I was a production welder/ supervisor for 17 years. 30 mig welders and 28 robotic welders in my department. We changed out lots of liners and never had a problem using a good pair of welding pliers.
jayincville is offline
Old 09-03-2010, 08:36 PM   #13
MLScott&Sons's Avatar
Trade: structural steel and misc. metal fabrication
We always use a grinder and a cut off disc. push liner in and mark at gun end, pull out (allow for difusser), Cut deburr with disc and slide back in. It's not much harder than changing a spool of wire.
MLScott&Sons is offline
Who installs the shower pan liner in your area? pgc555 Plumbing 51 10-19-2009 06:49 PM
vinyl siding cutting table platinumLLC Windows, Siding and Doors 16 08-15-2009 11:54 AM
Polyurea Liner Removal by Water Jetting painter213 Pressure Washing 1 11-27-2008 08:29 AM
liner integrity tip (at sales calls) dirt diggler Pool Construction & Enclosures 1 03-06-2007 01:27 PM
Determining Manhours for rolling vs. cutting - your suggestions would be helpful Zeebo Painting & Finish Work 9 06-02-2006 06:12 PM
