AISC Steel Pipe Column On Conc. Curb Wall
Old 08-20-2007, 04:59 PM   #1
Atlantex's Avatar
Trade: Residential Development
I have a project where a 3.5" AISC standard steel pipe column will bear on a concrete wall to support a W-beam above a garage door opening. I'm wondering if anyone can point out a particular book or document where I can find out how wide the concrete wall needs to be to support the pipe column and the specific attachment details for the column to the wall. I'm also trying to find out the size of the plate on either end of the pipe column. Does the plate size vary by steel manufacturer or is that AISC standard as well? So far the only thing I've found is the AISC Steel Construction Manual but as it's $350.00 I'd like to be sure it's the book I need before I purchase it. If anyone can shed some light on this for me I'd greatly appreciate it. Thank you in advance.
Atlantex is offline
Drain Pipe denick Excavation & Site Work 18 07-12-2009 04:41 PM
framing a door in a steel stud wall River Rat Dad Framing 5 10-21-2006 07:37 AM
Pipe through brick wall gnahthe Plumbing 12 10-01-2006 01:08 PM
ideas for wood stud wall attachment to steel "I" beam? durham Construction 9 05-10-2006 06:45 PM
