solar guy
Trade: solar contracting
Suspended Drywall Ceiling C Channel And Hat Channel
Alright I got the local code enforcement guy to go along with the suspended drywall ceiling talked about in another post.
I have been looking around on line for suppliers or specifications for a channel and hat channel ceiling system. Everything for drywall seems to be a t channel like a tile suspended ceiling. The problem is that the bar joists to hang from are 6' on center and the max span between wires is 4 feet. Does anyone know who still makes the c chanel system? |
solar guy
Re: Suspended Drywall Ceiling C Channel And Hat Channel
Anybody?
solar guy
Please?
solar guy
Pretty please with sugar on top?
Trade: carpenter
you might have to run unistrut between the joists. I was just up in one the other day and they used 2'' metal studs hung @ 4' oc than screwed more underneath them at 16" oc..... it had been up there a while it looked like they could of used some more wires....
Abandon the search for truth settle for a good fantasy |
Trade: Consultant
Just shoot the wires to the metal deck between the bar joists- it's done all the time.
special ed
Trade: builder home improvements
building specialties on Hammond's ferry road carry's both types of grid the tee and the hat channel
the grids they sell are fire rated and they have the manufacturer specs. for the permit police |
Trade: General construction/ remodeling
if you have an AMS in your area they sell the stuff
#9 | |
Trade: Acoustical ceilings
Re: Suspended Drywall Ceiling C Channel And Hat ChannelQuote:
Trade: acoustical dry wall
Armstrong makes a six foot cross tee . just went to a Armstrong seminar lots of new sheet rock grid ideals i really like the three holes at each cross tee attachment on main tee . all so they make 50 inch cross tee so the main wont bee in light . also have new wall angle that holds tees on 16 inch centers without a screw cool dude in broken arrow ok.
Trade: steel stud/drywall
chicago metallics wiil carry most everything you need they also carry a hanger that you can either screw to deckin or shoot depending on the substraight above
Trade: Remodeling/building
Make a grid with the hat channel. First grid on 6 foot centers over the hangers then the grid conneced to it on two foot centers running the opposite way. Use the L channels against the studs. Use hat channel for your runners.
At least thats the way I did it and never had any problems. Mechanical rooms had to have fire coded rock on the ceiling. Not dropped ceilings. |
Trade: retail stores
calply has it westside, also carries it you must live outthere in the boomies california has it all
#14 | |
Doofenshmirtz Evil Inc.
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber |
#15 | |
30 years +
Trade: drywall, metal stud and act ceilings
splay the wires ...2 wires from 1 joist ....2 ft one way and 2 ft another ...your problem id fixed...I do hat channel ceilings for a living...or you can use chicago grid, witch looks like act grid...either way you need thye wires at 4 ft on center
#16 | ||
Wood Craftsman
but where does the meet go.?.......and how do you turn it on ? your not qualified to run this machinery Elane.............Siefeld: Slicer episode~Cramer
Better yet~ the "scarable episode" ......qwone!........ that's not a word......? yes it is...you never heard the phrase "To Qwone someone" --classic! Sometimes I just like to Splay around ... Cramer, Last edited by PrestigeR&D; 07-15-2010 at 05:27 PM. |
#18 | |
Trade: Siding Windows Metal stud sheet rock grid ceilings
Absolutley, this would be the easiest method to still use sheet rock grid. Double up the wires and let them angle. NOt to far though, there is still a code on the degree to which a wire can angle although im not sure the degree. also starting your grid with a wire pulling your grid back to that starting wall allows you to work away from it with minimal use of clamps, although you will be screwing the grid to your wall mold with pan head screws once you got it all squared up. |
