Soil Compaction
Old 05-06-2008, 08:38 AM   #1
joasis's Avatar
Soil Compaction
Anyone have a link to a site that discusses soil compaction and the weight of concrete?
The basement dig I am on is getting to be worrisome....not more then a few feet over the water table, and we are not getting good compaction with a rammer. My calculations come to about 5 pounds per sq/inch load on the base footings, and less then 2 on the floor.
I will probably call an engineer today, but any information would help.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 05-06-2008, 09:30 AM   #2
PRO
Blackhammer's Avatar
Trade: CGC Concrete
Re: Soil Compaction
Alot of times the weight of the concrete is speced in the mix design. I have always used 4000 lbs. Most of the mixes I use are between 3850-3950. It sounds like you may need to set up a well point system to lower the watertable long enough to obtain proper compaction and pour.
Blackhammer is offline
Help with Soil Volume to Weight? onelane Excavation & Site Work 12 12-13-2007 08:46 PM
Excavator Mounted Compaction: Static roller vs vibratory roller or plate artherd Excavation & Site Work 5 07-02-2007 10:36 PM
Ground rods for soil with bedrock MKamis Electrical 5 03-08-2007 09:47 PM
gate valve compaction tool dayexco Excavation & Site Work 4 04-19-2006 07:46 PM
Compaction Quiz denick Excavation & Site Work 8 04-17-2006 11:33 PM
