solar guy
Trade: solar contracting
Smoke Walls
I have taken a job with a solar energy company. My past experience has been in residential construction, solar and plumbing. We have rented a warehouse space that our office will be in. Right now it is wide open and not air conditioned. We need to build some office space within the warehouse so we can have conditioned space to work. The county is requiring us to have smoke walls separating the storage area from the office space. The ceilings are 18' tall to the deck steel bar joists and a bunch of wires sprinklers etc. The office is in anne arundel County Maryland
My question is instead of taking the walls to the deck is it within code to install a drywall z bar ceiling as a smoke barrier above the office space as opposed to taking walls to the roof deck? this would save a tremendous amount on relocating space heaters etc. Thanks in advance for your help. |
solar guy
Re: Smoke Walls
come on guys anybody?
LRG WoodCrafting
Re: Smoke Walls
Never heard of a smoke wall.
solar guy
Re: Smoke Walls
it is similar to a fire separation wall but with no long term fire rating EG 2 hours etc. Designed to keep smoke from penetrating from storage area to office area. I never heard of this either. Fire separation walls are already in place between tenant space.
LRG WoodCrafting
Re: Smoke Walls
If that's the case why can't you use a plastic sheet. That will keep the smoke out. What smoke are we talking about anyway. These guys smoking stogies in there?
Tech Geek
Trade: Property Management/Facilities Manager
Re: Smoke Walls
I've always had to take them all the way up. Is there a way to divide the area (between the warehouse and offices) with 1 rated wall and shorter walls as the office partitions?
Re: Smoke Walls
Yes you should be able to do that, most of the warehouses are like that around here.
In our warehouse I made the ceiling joists over the office as floor joists so I could use the space above the offices for storage. |
solar guy
Re: Smoke Walls
this is what they are specifying. the office space is pretty open and the additional walls are twice the area of the ceiling.
solar guy
Re: Smoke Walls
This was my first choice but the slab is not rated to mezanine the space so storage above is not an option. However I see no difference between this and 16 feet tall steel racks.
#10 | |
Re: Smoke WallsQuote:
Or are you thinking of using a hard lid on your office space, and using that as a smoke separation? If so, that would be up to the AHJ |
Tech Geek
Re: Smoke Walls
So I would just build the 1 tall wall then have the ceiling guys come in and grid out the entire office space (fast and cheap if that's what you're looking for). Then attach all of the office walls to that. I guess I'm just not understanding what your reasoning is for wanting to drywall all the ceilings verses building one tall wall.
solar guy
Re: Smoke Walls
Yes this is what I had in mind. Since I do not own a copy of the IBC will this satisfy the code requirement? BTW what is tha AHJ I am a little slow tonight.
Re: Smoke Walls
AHJ: Authority having jurisdiction
I'm thinking that you are going to have to build a wall that is for all praticle purposes a demising wall between the offices, and the wharehouse. This wall should go to the pan deck ceiling, and probably have a top track built as a deflection track. The GWB may have to scalloped to meet the pan decking. Hopefully, the AHJ will expect much less |
Tech Geek
Re: Smoke Walls
AHJ=Authority Having Jurisdiction
EDIT:too slow |
#15 | |
solar guy
Re: Smoke Walls
It's really common in commercial work. Slow, and you'll need a lift. Some sprinkler heads may need to be moved due to the new walls. Here, a head can't be withing 6" of a wall. But I'm sure you'll have quite a bit of sprinkler work if a new grid ceiling is going in.
#17 | |
solar guy
There is a bathroom in the warehouse space with a hard lid and that seemed to pass will have to go the permit office and whine. |
#18 | |
2) It is still unclear what a "smoke wall" is. I assume that it is local vernacular for a one-hour rated demising wall. But it may mean something else. 3) The fact that the bathroom passed with a hard lid probably has no bearing on the offices. The bathroom probably has a limited occupancy, and its use is transitory in nature ( it is in limited use). The occupancy of an office area is entirely different, and the concerns of the building and fire codes towards the occupants of these offices are of an entirely different nature than those posed by in the warehouse setting. |
#19 |
superdave111a
Trade: general contractor
Re: Smoke Walls
just run em to the deck anne arundel fire marshals are the pits.
| Tall walls (2-storey walls) | Zoltar | Framing | 21 | 03-11-2009 01:00 AM |
| here's a painting price list...... | Jer44 | General Discussion | 9 | 02-17-2009 08:30 AM |
| Sanding Walls with 80 Grit Paper on Orbital Questions | plazaman | Painting & Finish Work | 5 | 12-19-2008 04:01 PM |
| Why Build ICF | monsterconstruc | Green Building | 32 | 09-28-2008 11:48 PM |
