Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Construction > Commercial Construction
Old 03-05-2009, 08:20 PM   #1
Ideal Building Concepts
Trade: General Construction
Seam cover for 4'x8' Wall Panels
Hello,
I am looking for a way to improve a certain area of our product. We install buildings or rooms that are completley black on the inside. Ceiling, Walls, Flooring, Doors, etc. Our installations are never local, so we try to pre fabricate as much as we can. Most of the time we are installing these overseas. Currently we are using black 15/32" Marine Grade 9-ply Plywood with a black laminate finish for our walls which are usually 16' tall. (4 rows in height)
Consequently we are creating a lot of seams between the boards that need to be covered up. Right now we are using 1/8" thick rubber flooring that we purchase on a roll (let's say it's 100' long and 20' wide) and manually cut this flooring into 2" wide strips. Then we back it with a heavy duty double sided tape (imported from Germany), roll it up and ship it in boxes to our site where the install team rolls it on the wall.
Obviously we have a lot of labor in this part of our product, not talking about the margin of human error, resulting in decrease of quality in our product. We have also been having issues with the glue of the tape in extreme weather conditions causing the 'seam tape' to come off the walls.
I know I could have custom rubber strips made up from different manufacturer's but that would only solve part of the problem and is not my first choice. Would love to obtain a few alternatives.
Is anybody out there that has a decent idea; what material to purchase; and where to find it? It needs to be at least 16' long and available in black. Preferably in the area of 2" in width.
Thank you for any help out there.
Here is a picture of the wall panels that I am talking about to get a better visual.
idealbuildingconcepts.us/img/wallpanels.jpg
IBC_Rob is offline   Reply With Quote
Old 03-09-2009, 02:24 PM   #2
Pro-Fit mouldiings
Trade: carpentry
Possibly a channel similar to what is used for f.r.p. installations?
Don't know how much of this material you usebut I would estimate the tooling cost at $2,000 or so.I was unable to open up your link to look at application.
"A good reputation is more valuable then money."
The Invetor is offline   Reply With Quote
Old 03-19-2009, 11:39 AM   #3
Trade: commercial contractor
rubber roll on roofing
Try using rubber roofing material it comes in black is plyable and is flexible
Originally Posted by IBC_Rob View Post
Hello,
rebelrobb2 is offline   Reply With Quote
Old 03-19-2009, 11:58 AM   #4
Trade: Build, Remodel, Roofing, Siding etc...
are you only using the backer on the lateral seams or vertical also? As previously stated some type of roofing material could be used. Maybe EPDM seam tape, or something similar would work.
question: why are your 4' butt seams not staggered? this may help with the backer. It would make it a much stronger finished product.
Taitco/Tait Roofing Inc
Est. 1973
www.taitroofing.com
TaitINC is offline   Reply With Quote
Old 03-23-2009, 12:05 PM   #5
oklahoma GC
Trade: Commerccial General Contractor
what about an accent strip for vct flooring
Butch
lakerat is offline   Reply With Quote
Old 03-23-2009, 02:03 PM   #6
There are steel studs 2' OC behind the panels. Every 2' horizontally and every 1' vertically we have a fastener in the panel, but not on the 'inside' of the panel. Just around the edges. We cannot stager the panels because that would create too many seams that need to be covered since these panels are the finished product on the interior. From past experience we havn't had any problems as far as panel support. ALL seams need to be covered.
f.r.p.? fire resistent paneling? Not sure what you mean by that.
Thanks for the input so far, ill research some of that. Need more.
Old 03-23-2009, 02:56 PM   #7
mdshunk's Avatar
What about black T-mold that's used on the edges of laminated tables? Shim the panels exactly far enough apart to tap in the T-mold.
mdshunk is offline   Reply With Quote
Old 03-24-2009, 01:15 PM   #8
Not bad. Is that available in a greater width? (2" instead of 3/4"? Maybe 1 1/2") I'll try to find it myself.
Thanks!
Old 03-24-2009, 01:36 PM   #9
Trade: .
DiversifiedHR is offline   Reply With Quote
Old 03-25-2009, 07:49 AM   #10
Trade: Maintenance Mechanic
Originally Posted by DiversifiedHR View Post
Take a look at Outwater Plastics. I've used them in the past, with quite a few different insert options.
Outwater is great, I use them all the time. I get black edgeband for some of the tables and shelving I make. I get it in 1 1/4" width from there. I am pretty sure they go wider.
FRP is fiberglass reinforced panel. They may make something similar for the thickness you are looking for. I know I have seen the "dividers"(as I and my supplier call them) in at least 1/4" maybe 1/2" also not sure. I will ask my guy and post his answer.
jackofsome is offline   Reply With Quote
Old 04-03-2009, 01:32 AM   #11
Response
Check outwater plastics (products)
they have a website, or just a home depot mullion
consolidatedbui is offline   Reply With Quote
Laying new ceramic tile on wall faromic80 Ceramic & Stone Tile 4 09-17-2008 07:01 AM
Buckling Exterior Wall Duntov Framing 15 09-12-2008 07:33 PM
Major wall frame remodel Jackpine Framing 0 09-03-2008 09:06 AM
Refridgerator Panels for Kitchen trex Kitchens & Baths 6 04-02-2008 04:06 PM
removing a none load bearing wall?? samiam Framing 7 09-12-2007 07:33 AM
