Trade: Fire Suppression Equipment Sales & Service
Plywood W/one Hour Fire Rating
A client is building a concession trailer. He builds about 50 - 75 specialty trailers per year, but has never done a commercial kitchen before. The theory is any concession trailer is to be built to Oregon Mechanical Specialty Code. Code requires a 1 hour fire rated wall between the Type I exhaust hood and combusables. Of course, I told him all he needs to do is screw a single layer of 5/8 sheet rock down and hang the hoods. He told me the sheet rock would not last 10 miles on the hiway before it broke all to pieces. He then asked if I knew of 1 hour rated plywood. I am not aware of any 1 hour plywood. Is there such an item as 1 hour plywood? And if so, who makes it?
Restoration Crazy
Re: Plywood W/one Hour Fire Rating
Jason E Whipple, General Manager Historic House Restoration, Cincinnati, Ohio Facebook | Twitter |
why not use some frp?
Re: Plywood W/one Hour Fire Rating |
Interested in why they would think
that after a one hour fire anyone would care that there was one wall left on that trailer.
#6 | |
Trade: High Rise Caulk and Insulation
Re: Plywood W/one Hour Fire RatingQuote:
A 1 hour wall is only a 1 hour wall if it has both sides of the wall, which, in the case of a vent hood, would mean you have to have a shaft wall and you probably don't have room or money for that. I insulate vent hood exhaust systems in restaurants that are wood frame contruction and the latest in technology is the fireblanket from 3M Firestopping. The installation instructions seem to be very intricate but after you read them for the 5th time, things become more clear. ![]() Google "3m firestop distributor+your closest big city name" and you should be able to find a fast, cost efficient solution. If you need specifics, shoot me a pm or email at rrowe@firestop-llc.com Good luck.
its not going to get better with straps, or new footings or even aroma therapy.
I usually use the 3M 15A on ducts. It is expensive, but faster and much less expensive than framing a chase and putting in a layer of 5/8 sheet rock and getting it mudded. In Oregon, we are allowed to use a single layer of 5/8 for a 1 hour rating. For complete hood installs, I use a local sheet metal shop. They use another brand, 2 " and only a single layer. It is less expensive than 3M. Some day I will write down the name, and change over from 3M.
I have already told my customer that I strongly recommend he use the 3M insulation for the ducts. This kitchen part of the job was speced and started by another company. they installed low proximity eyebrow hoods. they should have used canopy hoods. There will problems with the clearances, head room and clearance to combustable. The duct is at the edge of the roof, the ducts will have to come vertical out of the roof and then horizontal so the exhaust fans won't be hanging over the edge of hte roof. There fans look like they are going to pull too much air. The make-up air is not adequate for the amount of exhaust, plus there will not be 10 feet between the intake and exhaust air. The hoods and fans are from Captive Aire, but there is no job # on anything, so I cannot verify if the fans are matched to the hoods and appliances. We do not even have the complete appliance list yet. I really wish the end user had made some inquirey before starting this job. I will have to have the suppression system tank bracket custom made for the job. I have no idea where we will get enough room to mount our tank, or how we will run our pipe so as not to interfere with the kitchen equipment. |
#8 | |
I certainly do not want to tell you your business so take the following with a grain of salt. Eventhough the inspectors allow you to do this, it is still contrary to the code. UL or any other testing agency does not have a 1 hour fire rating for a one sided wall (if I am understanding you correctly), as walls have two sides. You will be liable in a court of law should there ever be a fire and the attorneys find out you violated code, whether your violation caused damage or not. You will still be sued and have the expense of defending yourself. Looking at it from the other direction (my sales technique for customers who want to cheat in order to save money), "Sir, you are putting yourself at great risk financially if you do not do this per code", then you make money (more) when they decide to do it properly. Fear is your friend
Trade: Superintendent for Commercial GC
I use Hoover PyroGuard (google it, available through most lumber yards) plywood when needed. Keep in mind that materials aren't rated, assemblies are. If it is to serve as a firewall you will need a UL assembly diagram.
| Hardi fire rating | K_Tile | Windows, Siding and Doors | 6 | 09-09-2008 05:26 PM |
| One hour fire seperation | baccel | Commercial Construction | 7 | 09-29-2007 12:27 AM |
| Fire rating lathe and plaster ceiling | adianz | Construction | 4 | 04-14-2007 07:02 AM |
| Top mounted hangers against fire rated plywood, do studs and joists need to line up? | personalt | Carpentry | 2 | 08-20-2006 04:24 PM |
| Where's my thread? (Politics anyone?) | AAPaint | Off Topic (Non Trade) | 175 | 08-16-2005 01:45 AM |
