I need to put a couple partition walls up in an office space. One of the walls will have a door and two windows. There is a drop ceiling in place at 10'. I haven't secured a wall to a ceiling grid before so I just thought I'd throw this out there to see if I might get a couple tips. I plan on just securing my ceiling track to the T-grid, one self tapping screw on each side of the T.
I guess my main concern is with the door. It seems like I need to secure the wall around the door from above the grid. Someone suggested that I U-bolt a 2x4 down from the metal roof structure and secure up the ceiling with that, although I can't really picture how you would attach to the T grid.
Finally, what are the options for finishing the drywall along the ceiling? Is running some moulding up there the only option to hide the gap of the drywall and ceiling tile?
Any feedback is appreciated. Thanks in advance. I'll attach a couple pics of the office space and the view above the ceiling tiles. (The partition wall with the door will be running perpendicular to the main roof truss in pic.)
No fire alarm. What would be the legal problem. I didn't see anything in the architects drawing and notes about anything with the sprinkler. It just says that the drop ceiling is to remain.
I've seen studs used, screwed to top plate and angled back to a joist where it gets screwed or shot or beam clamped(in a pinch..) I got respect for the metal guys around here, a few snips a few screws and solid as a rock. I was always in way after them.
Ceiling tiles notched around neatly so you can't see.
Sounds questionable. When I have done that the new walls are built full hight and the ceiling is reconfigured for the new arraignment. The lights, hvac, sprinklers and so forth have to get sorted out according to the new configuration.
This is done all the time around here. But like griz and others mentioned the biggest thing is the sprinklers right now. Each head is placed to cover a certain area of the building. And heads are spaced appropriately to make sure the whole area is covered. Now if you come in and throw up a wall you might be screwing up the sprinkler coverage. For example, let's say you build a wall one foot away from a sprinkler head. That sprinkler head used to cover a certain radius. Now you blocked off almost half that radius and the area on the other side of that wall is no longer covered. You would need to add another head.
And also as mention you will be changing the whole design of the HVAC system as far as register locations and cold air returns and the system will need to be redone and balanced. Lighting code requirements may change also if you put up walls.
As for your enitial questions yes it can be done. Personally I don't like to fasten to the grid. These places change a lot and when you take a wall down the grid will be ruined. I frame my wall and the use some steel studs to kick it to the deck. This is easy and will be stronger. Then notch the tiles to fit. Tiles are a lot easier and cheaper to replace when you need to change things. For the drywall I use a tear away trim usually. Finish the drywall and paint and you are good.
The fire protection system will have been designed based on that room layout, adding a wall will change it so the Architect should have had it checked by the fire system designer.
#1 Screw the top plate to the grid. Not my favorite way to do it, but if that's what the owner and the architect want, it's not my place to argue. I don't like the holes in the grid. They are thinking they can change the walls if it get rented to a new tenant. I'm just thinking, there's holes in the grid.
I do like a kicker to the top of the wall, but that is never specd. If I do it, it's on my own. Architect never details that.
#2 I use tearaway bead at the top. There are times they don't even want us to tear it off. They say to leave it. It looks fine and lets face it, it's commercial, nobody even notices.
#3 The sprinkler system will need to be addressed. It is possible all of the heads will hit where they are supposed to hit. Maybe not, but unless it is your job to do the sprinkler system, then it's not your problem.
#4 HVAC. Usually there needs to be some shifting of the ducts. Unless you are the HVAC contractor, this does not affect you.
Don't forget cold air returns. Again, unless you are the HVAC contractor, not your problem.
#5 Lights. They usually need to be shifted as well.
$6 Egress and emergency lighting will need to be checked. But....that is for the architect to figure out. The emergency lighting is also for the architect to figure out. The electrician will just put it in the location the architect specifies.
There are all kinds of arguments that this or that should be done. The reality is they hired an architect and got an inspector to sign off on the changes. It's your job to do what they want.
Builditguy - props to this response - it was by far the best and most cohesive, all of your points make complete sense. The recommendation on the tearaway is great.
-The sprinkler heads are a non-issue, the walls are not interfering with their coverage.
-One light is getting moved over 2 tiles, that's all that's needed.
An electrician will take care of moving the light over and hanging an Exit light and installing the outlets and switches.
As far as I can tell, I just need to make a couple strong walls that don't shake when someone slams the door. And skim coat 1400 sq/ft of textured drywall... my shoulders are complaining already.
Thanks to everyone who has posted so far, I really appreciate the insight as this is unfamiliar territory to me and you are really helping me a lot.
Check the code, if the area is over 1000 SF you will have to do a fire separation above the drop ceiling, so one of the partitions you will have to run to the roof line or do a drop ceiling to roof line separation.
we use grid clips,they clip on grid than screw to track,they are good so you don't mess up the grid if the wall ever gets moved,we just use them to hold the wall up until we get kickers on it, cause our code says walls and ceilings have to be independent,we usually have a spec on our print for kicker detail.to finish top of drywall off just use tear away trim,
I typically will attach the top track to the ceiling grid than add a few kickers to the top of the track to building steel. I have built miles of wall this way and never had a problem.
I don't know why you would not use grid clips so you don't have to screw into the ceiling
Related Threads
3.5M posts
151.3K members
Since 2003
