Trade: Handyman
New Door Install Help
Hello all,
I have drywalled a new storage area room at a commerical building. Now I need to make a doorway thou existing wall on the backside of the storage area. Does anybody know the dimensions that I should cut out of the wall for the door. I am putting in a 36" door and frame. After many years in handyman and maintenance business I have never cut a hole in a existing wall to make a doorway. Any help and advice you can give will help alot. Thanks Dennis |
Re: New Door Install Help
really depends on whether or not the wall you are cutting into is load bearing or not
you said comm building, so i'll assume it's metal studs - make sure to cut carefully unless you just like being shocked or flooded, or both! as far as the opening size, just go buy a prehung door and it will say right on the box "rough opening size requirements" (or don't buy it, just read the box) I make it 1/2" wider and taller than the frame size, so you can shim it level and plumb when you set it MHM |
JumboJack for president!
Trade: Hilti walking billboard
What is the exterior wall material? Concrete block, brick, stucco, wood, etc? Will you need lentils to support weight? just some additional things to think about. I agree though 1/2 to 1" is good room to wiggle.
Cabinetmaker
Standard procedure you make the opening plus 2" in both width and height.
IE 30" door RO is 32 x 6' 10". Standard height of RO will be 6-10 if normal 6-8 door. so Door width plus 2" |
Ya gotta watch it, theres no standard procedure therma tru is 2-1/2" frame Gotta check the door first
#6 | |
Carpenter, babysitter
Trade: Commercial Construction and Installations
Re: New Door Install HelpQuote:
I retrofit hollow metal doors/ frames all the time. Over all dementions of a 3-0, 7-0 is 40 1/8" by 86". Assuming this is a stud/ drywall wall, use a knock down frame to retrofit a 3-0, (assuming a 7-0), cut your opening to 38" by 85" . This will allow you shift the frame/ door side to side or by lifting hinge or strike side to compensate for an uneven floor- set your margins . Of course you want to re-frame your door opening like you would otherwise, tyeing everything back together. If its load bearing stud wall, then you will need to header it with jack studs. Masonry wall: Then you need a welded frame, (6" width for inset) cut opening 1/2" larger then you door frame IE: 40 1/2" for a 36 wide door and you"ll need to lintel off the header as mentioned above, make sure the height from floor to bottom of lintel is 86 1/2 to give a little extra again, for a 84" tall door. Hope this helps. This gives a rough explanation of what your wanting to do.
Jeff |
Trade: handyman
-sorry wrong post-
Trade: carpenter
I think your talking about a block wall, so im going to say masonary hollow metal welded, rough opening 40 1/4 and mason frames come with a 4 inch head so add that to the hieght of the door. The frame comes pre dimpled for your red heads or lags . and depending on the fire rating you might have to fill it with structo-lite.
#9 | |
that answer since February?
Trade: carpenter
oops, now i know where the date of post is
You wuz tricked
![]() Happens a lot, someone digs up an old post, next thing, a lot of people talking to ghosts.
