Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Construction > Commercial Construction
Old 02-25-2009, 07:54 PM   #1
Trade: General contractor
Need a 2 hr fire rated wall design
Hi I have and existing 2 hour fire rated wall built out of 3 5/8" metal stud with 2 layers of 5/8" drywall on each side. I cut in an opeing 8' x 10' for access so my cleint can put a large boiler in. I wanted to close the opening back up by headering it off and using metal stud and then a non comp plywood on both side so that they could later unscrew it and have access again if needed.
Does anyone know of a UL listed design I could use to prove the 2 hour rating on the plywood knock out?
miked8282 is offline   Reply With Quote
Old 02-26-2009, 09:22 AM   #2
Snobnd
Snobnd's Avatar
Trade: Remodeling 30+ yrs
I think it would be best to put the wall back as It was.
Take a few pictures and Tape both sides.
We had a job in the local mall last year, Prints were approved, job completed just as the print showed.
The inspector for the fire department flaged us for firecode 3/4 plywood in the ceiling - MUST be covered!
3 days before the opening. We had to cover it with sheetrock and tape. I think I got stabed 50 times with with the ceiling wire. That sucked
Snobnd is offline   Reply With Quote
Old 02-26-2009, 10:39 AM   #3
Commercial Contractor
Mud Master's Avatar
Trade: Wood/Metal Framing, Carpentry(Rough), Insulation, Drywall, Plaster, Acoustical
Send a message via AIM to Mud Master
A fire rated assembly must be completly sealed off. I don't know of any UL that would allow you to just fire caulk the perimeters either. Not to mention it looking like sh*t.
3 Options:
1. Re-stud opening, 2 layers of Type "X" GWB, fire tape (or block/skim/prime/paint as well if area dictates)
2. Re-stud opening, 2 layers of Type "X" GWB, install fire-rated access panel. Though I don't they make one big enough to accomplish what you want.
3. Frame a RO, install fire rated door/frame/hardware
Yes, I am that damn good.
Mud Master is offline   Reply With Quote
The Following User Says Thank You to Mud Master For This Useful Post:
Deadhead Derek (02-26-2009)
Old 02-27-2009, 06:07 PM   #4
If you want access to it why not just put in a fire rated door?
Super-Mike is offline   Reply With Quote
Rheem Recalls to Repair Oil-Fired Furnaces Due to Fire Hazard MechAcc HVAC 0 01-22-2009 06:10 PM
Design Presentation - Going to Virtual fakie99 Marketing & Sales 6 01-22-2009 08:21 AM
Home Design Software - i.e. Punch Home & Landscape Design Panzer5 Technology 19 12-29-2008 11:09 PM
Plaster applied to interior of interior wall problems CMU General Discussion 1 10-14-2008 09:37 AM
Need to frame a wall over concrete wall. joseph Carpentry 3 10-07-2008 07:19 PM
