Loading Docks
Old 10-04-2009, 07:37 PM   #1
propmakerconst's Avatar
Trade: Steel construction and Inspections
Loading Docks
Having an issue with concrete thickness for a loading dock, dock will be 35' by 15' on W18's (cause I have a lot of them) B deck on three beams on 7'6" center on 15 posts. The primary use will be a 6k forklift lifting 2k pallets. My gut says 6 inches but the owner wants 8 to 10 which is a waste of concrete and makes it heavier than it needs to be on soil I do not trust.
I know this is vague and there are many factors but I am looking for the average.....
propmakerconst is offline
Old 10-04-2009, 08:10 PM   #2
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Re: Loading Docks
And the soil numbers crunched out to say what? A hunch isn't a lot to stand on, one way or the other.
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is online now
Old 10-06-2009, 09:37 PM   #3
woodchuck2
woodchuck2's Avatar
Re: Loading Docks
Well, i dont know if this will help you or not but i have some experience in loading trucks. The mine i worked at used lift trucks capable of picking 3ton so they weighed at least 7-8k lbs at minimum. Now when we were in a hurry it wasnt uncommon for me to be loading the truck and another lift truck bringing in 4 pallets "way overloaded" with 2k a peice on them. So you figure the weight of 2 lift trucks and anywhere from 6-8ton of pallets sitting next to the dock really adds up. This is in a 20'X20' area so i think you would want the extra support.
The warehouse i worked in was rather large and held at least 1000-1200 pallets, the pallets weighed anywhere from 2k-4k so there was millions of pounds on these floors. The floors were rippled from the lift truck traffic through the years of use/abuse.
woodchuck2 is offline
Me and Daisy loading trucks muddinman04 Excavation & Site Work Picture Post 3 08-21-2008 03:36 PM
Loading An Avatar CJKarl Masonry 5 05-21-2008 09:55 PM
Problems loading ContractorTalk.com? Nathan General Discussion 42 03-28-2007 03:05 PM
Up loading photo's to this site Frankawitz Site Help and Suggestions 4 12-20-2006 08:00 AM
proper way of loading of brush from a cutting pail Zeebo Painting & Finish Work 7 08-11-2006 11:58 PM
