| View Poll Results: If you are building a new home what would to prefer? | |||
| To build a Steel House |
6 | 50.00% |
| To build a Wooden House |
6 | 50.00% |
| Voters: 12. You may not vote on this poll | |||
Trade: Building Steel Houses - Custom Steel Internatinal
Light Gauge Steel Framing Or Red Iron Houses
Today there is a growing Awareness and Acceptance of Building Steel Houses using materials like Red Iron and Light Gauge Steel. Steel houses have greater strength in comparison to houses made of Wood. Additionally, you don't need to worry about fire, termites, hurricane, thunder storm or tornado.
Fellow members share your knowledge and views on this topic. Also shoot any questions that you may have on using steel for building your residential or commercial property. |
Trade: Bricklayer
Re: Light Gauge Steel Framing Or Red Iron Houses
You forgot the best option for your poll. All masonry home
CM, LEED AP, Attorney
Trade: Construction Management / Real Estate Law
Whatever is most cost effective at the time.
Twenty plus years of experience means you've seen many things and have more to see. |
Trade: Bricklayer
Re: Light Gauge Steel Framing Or Red Iron Houses |
| The Following User Says Thank You to NJ Brickie For This Useful Post: | essrmo (03-07-2010) |
There are no significant performance differences between metal and wood framed homes. Except in a fire, then wood is superior because it chars and maintains it's structural integrity well after the melting point of metal is reached. There are little to no true masonry homes constructed any longer, most are brick veneer. If you are talking about performance for an exterior siding product, brick is superior to most building envelope materials.
Trade: Fences
Wood, because wood is good.
Steel, because it's the real deal.
#8 | |
Trade: Bricklayer
Re: Light Gauge Steel Framing Or Red Iron HousesQuote:
My original post was just poking fun. I do believe an all masonry home, whether it be CMU, CMU with a masonry veneer, or an ICF home with a masonry veneer is the best home. I do know that most houses in the US are stick framed but to say there are little to no masonry homes is just untrue. A large portion of houses in Florida are masonry. ICF house construction seems to be gaining popularity also. The orginal question was about best building practices. Longevity,mold resistence, less worries about water damage, fire damage, thermal mass, quiteness, superior storm resistantance,and much less maintenance are some of the reasons masonry homes outperform stick/metal homes. |
The only thing about masonry is that it doesn't perform that well in seismic events. Other than that, it would be my second choice
KemoSabe
Personally, I've only framed one house with steel, up to the roof anyway. No doubt, the walls are straighter than with conventional lumber, but the increase in labor with the product we used is so cost prohibitive, that I would never use it on my own home.
If I had an unlimited budget, my choice would be to frame the entire structure with engineered lumber products. IMO, wood is just a much easier medium to build with and with proper tecniques and finishing details, will provide an all around nicer finished product. Bottom line is, to each his own. I'm a carpenter because I love working with wood, the tools, materials, methods, etc.
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
#11 | |
Maxi-Pier Tech
Trade: foundation specialist
#12 | |
Trade: Bricklayer
#13 | |
Maxi-Pier Tech
| Tags |
custom steel frames, custom steel structures, light gauge steel houses, red iron homes, steel buildings ![]() |
| how do you estimate steel stud framing? | Wensdy | Framing | 8 | 07-21-2009 09:18 PM |
| How many forum posters does it take to change a light bulb? | woodbutchr | Off Topic (Non Trade) | 15 | 01-22-2009 07:16 AM |
| 2 questions, arc fault & light feed | Burby | Electrical | 13 | 12-23-2008 04:50 PM |
| First time framing with steel studs | nywoodwizard | Remodeling | 10 | 05-01-2007 07:57 PM |
| framing a door in a steel stud wall | River Rat Dad | Framing | 5 | 10-21-2006 06:37 AM |
