Hellp
Old 11-16-2008, 10:44 AM   #1
matt grisham's Avatar
Trade: acoustical dry wall
Hellp
Looking for a laser that shots square lines on ceilling
matt grisham is offline
Old 11-19-2008, 08:33 PM   #2
72chevy4x4's Avatar
Re: Hellp
I like that..."square lines". Are you looking for something to project a square on a ceiling? I don't have experience with a tool which performs that function and would be curious as to whether or not it's possible. I know projectors have a feature called keystoning (I think...second hand knowledge) which keeps the picture square as the projector is tilted. This would be a big project when projecting onto a ceiling, unless it's straight up and the ceiling is on a horizontal plane.
72chevy4x4 is offline
Old 11-19-2008, 10:29 PM   #3
Re: Hellp
I need a laser to help whith ceilling grid. Keep it simple, laser would be my string lines
Old 11-21-2008, 05:15 PM   #4
parkshey's Avatar
Trade: steel & concrete
Re: Hellp
constructioncomplete.com they have a bunch of lasers in survey equipment.
I noticed they have a laser chalk line that you could point on the ceiling. that would only give you one line though.
parkshey is offline
Old 11-21-2008, 06:01 PM   #5
Trailer park boy
shanekw1's Avatar
Re: Hellp
http://www.amazon.com/Stanley-77-198.../dp/B0007SXI5O
shanekw1 is offline
Old 11-21-2008, 08:46 PM   #6
danf5195's Avatar
Trade: Independent Contractor
Re: Hellp
the pls180 or pls90 may do what you want with the accuracy also
i'm new here so it wont let me post the link but it's
plslaser dot com
danf5195 is offline
Old 11-21-2008, 08:56 PM   #7
Sean
SLSTech's Avatar
Re: Hellp
Rotary Laser - gives you your level for the edges & the field
Set your edges, do your layout measurements & away you go (No need for a laser)
SLSTech is offline
Old 11-21-2008, 11:23 PM   #8
TracyMC
TracyMC's Avatar
Trade: Commercial Construction management, Project Manage
Re: Hellp
Go to Trimble"s website they have what u need I will post with what we buy I justhave to go to the site and look real quick.
Tracy
TracyMC is offline
Old 11-22-2008, 06:51 AM   #9
John
drywallr41's Avatar
Trade: Drywall and Framing
Re: Hellp
I have installed "miles" of grid, I use the Hilti PR 25 rotary. It has card for attaching to grid so you keep it level thru out the span of your grid,is great for large areas and must have if you do alot of grid. It runs around $700.00 but pays for itself with the time saved,Good luck.
drywallr41 is offline
Old 11-22-2008, 11:20 AM   #10
TracyMC
TracyMC's Avatar
Re: Hellp
Hilti is a great tool, the Spectra 1452XL good as well it has a card, a remote, wall mount, and it is light , great for grid, but versatile, also.
Tracy
TracyMC is offline
Old 11-22-2008, 12:37 PM   #11
Re: Hellp
I have a PLS 360 and hilty 25 Whith remote.And 2 plum lasers But steel can not find a laser that i can set on floor and shoot two sq lines, that i can cut ceillig grid in . Needs a good line that showes on grid bottom whin done. Just like two string lines
Old 11-22-2008, 12:44 PM   #12
TracyMC
TracyMC's Avatar
Re: Hellp
Matt, Maybe I am missing something but , I think I may have an Idea, Search for a Robotoolz Laser, has a dual head rotary that can be laid on its back to produce 2 lines perpendicular to each other if necessary.
Tracy
TracyMC is offline
Old 11-22-2008, 12:51 PM   #13
Re: Hellp
Tracy
THanks i will chek it out
Old 11-22-2008, 01:00 PM   #14
Re: Hellp
So far all lasers i have seen thay give two sq lines but not straght up on seilling
Old 11-22-2008, 01:08 PM   #15
TracyMC
TracyMC's Avatar
Re: Hellp
Its called a Robotools Dual Plane Laser
TracyMC is offline
Old 11-24-2008, 05:56 PM   #16
oklahoma GC
lakerat's Avatar
Trade: Commerccial General Contractor
Re: Hellp
what is the problem with running a quik string line. I can see where it could take a longer to set the laser as it would to run out a line (or at least some of the guys that work for me). Hilti PR 25 is about the best you can do for the $$
Butch
lakerat is offline
Old 11-25-2008, 01:21 PM   #17
DanTheMan9727's Avatar
Trade: Carports
Re: Hellp
Yeah, those are what I use. What the fifth poster had up.
metal canopy | carports| metal carports
DanTheMan9727 is offline
Old 11-27-2008, 11:01 AM   #18
plazaman's Avatar
Re: Hellp
I have a hiti laser, great tool... used for drop ceilings on numberous jobs
plazaman is online now
Old 11-27-2008, 11:37 AM   #19
Daniel Powell's Avatar
Trade: Construction Consultant, Stone & Tile Expert
Re: Hellp
Your basic Stanley, available at Home Depot, at a cost of $200 has level, plumb and a lock setting for square. Lay it on its back and twist it to align with walls. Don't remember the model, I'm afraid.
"If you're not gonna do it right, don't do it". My father
Daniel Powell is offline
Old 06-04-2009, 06:58 AM   #20
dadkins0005's Avatar
Trade: hanger,framer,finisher,accoustic ceiling installer
Re: Hellp
with that pls and hilti, and the plum pointers, only thing you need is someone to build it. ive ran grid with just strings. as far as to running lines under the grid after it is ran with laser. patent that idea along with the one about the need for a scaffold that rolls auto and goes up and down.
dadkins0005 is offline
Hellp needed Mactrevoc Help Wanted or Looking For Work 0 02-18-2007 03:45 PM
