Trade: General Contracting
Fire Rated Door Vent?
Do they make a door vent that you can retro-fit into a solid core fire rated door that uses a fusable link or something to maintain the fire rating in the door? We have a mechanical room that needs additional venting and I thought this might be a solution.
-John We'll have to grab a longer board. I forgot to put the wood stretcher in the truck today. |
Re: Fire Rated Door Vent?
By the tone of your question, you seem to realize that a variety of smoke and heat dampers are available. Some require electrical wiring controlled by an alarm system, and some use a heat activated mechanism only. What is required in your area is impossible to guess at, but comes down to your local AHJ and whether the building is alarmed.
I would think that a better alternative would be to put a vent in a wall near the door, and not in the door. This is because fire-rated doors are an UL assembly, and adding to these doors can really befuddle code interpretations |
Ok. So, I guess my question is: Does anyone know anywhere online where I can look at such vents with fusable links?
Here is a link to Shoemakers site,
http://www.shoemakermfg.net/?page_id=61&cat_id=47 There are several manufactures who make what you need. Depending on your application, here are some pointers. 1) A building with a alarm system will generally require a damper wired all the way to the FACP. 2) Some dampers require a specialized framing detail. But they can generally be fitted into a wall somehow. But you may have to install studs top to bottom on either side of the dampers 3) Your HVAC guy is normally the person knowing the most about these dampers, especially if they have commercial and multi-family experience. 4) If you do need to wire it in, you are probably going to need both a sparky and a LV guy involved. I hope your FAC panel has enough poop. The first time I installed one of these, it was a minor epic. Now I have done so many, I have the paperwork and details wired, it is almost moot |
Motorboatin' son of a ...
National Guard Products http://www.ngpinc.com/products.cfm?f...at1&category=4
Excellent sleuthing BF. I wasn't aware of those. Looks like all the UL paperwork is fine. I would suggest that the OP use what you have suggested, it is much easier than anything I know of
I googled door louver+fire+UL rated, and got ton of good hits
Trade: Doorfitter
Re: Fire Rated Door Vent? |
Thanks guys!
It is a mechanical room, and not an elevator machine room, right?
| Fire Rated Pocket Door | adirusso | Construction | 20 | 04-30-2009 08:44 AM |
| Newbie... What's fire rated? | The Cali Ex-Pat | Remodeling | 6 | 04-09-2009 12:58 PM |
| Need a 2 hr fire rated wall design | miked8282 | Commercial Construction | 3 | 02-27-2009 06:07 PM |
| Fire rated drywall | natalinizm | General Discussion | 4 | 07-10-2008 08:08 AM |
| fire rated party walls | tdmyturn | General Discussion | 3 | 02-29-2008 09:29 PM |
