Exterior Double Doors
I am doing a lease build out and part of contract is installing a 6'-0" x 7'-0" set of receiving doors. Here is my question, does the flange on the astregal (sp?) go on the inside or the outside? Most of the ones I've seen are on the inside but to me that makes the opening smaller and I wonder if that meets ADA specks. I'm sure there must be a correct way just not sure what it is or why.
Thanks in advance for your input. |
Trade: Framing,Remodeling,General Contractor
Re: Exterior Double Doors
Depends on which way the door swings
NKLHD |
I normally put them on the inside, on the passive leaf. You are correct, that could make the door non ADA compliant, but no BI has ever brought that up.
Are you going to flush bolt down the passive leaf, or install an indexer? |
Doors swing out. So if the door with the flange is on the inside the other door is the active door which makes the opening smaller, but if the flange is on the outside that makes it the active door and the opening would be larger.
Flush bolt
Flange on the outside can also act as an anti-tamper device to protect the latch, if that is applicable.
If you use a flush bolt, that inactive leaf is no longer counted as a fire exit door, unless the flush bolt is activated by the panic hardware. But I'm sure you know all this |
| The Following User Says Thank You to Anti-wingnut For This Useful Post: | Traveling Super (05-07-2009) |
| cost to stain pine interior doors | jreiner13 | Painting & Finish Work | 12 | 02-26-2010 08:01 AM |
| 24" exterior doors - where to buy? | Panzer5 | Carpentry | 11 | 05-07-2009 08:43 AM |
| Selling exterior doors......rant | Tom M | Windows, Siding and Doors | 21 | 03-28-2009 10:02 PM |
| century old wooden doors | joeslob | Sandblasting | 8 | 01-25-2009 03:08 PM |
