Carpenter
Expanded Metal In Security Wall?
I have a project coming up that requires installing expanded metal in office walls for security. Over top of the expanded metal will have doubled 5/8" Type X drywall.
I have not used expanded metal in this application. Should it be wire tied to the metal studs, screwed, welded? This is a relatively small wall area that is getting the metal (approx. 10 linear feet x 8' tall) Also, what is the best way to cut it?
"An idea is salvation by imagination" Frank LLoyd Wright |
Trade: Carpenter/GC
Re: Expanded Metal In Security Wall?
Screw it on with fender washers, metal cutting blade in saw/grinder
Trade: GC/Remodeling
A bank? If it's for security, attach it well, and put it on the 'threat' side.
Kinda like putting fence wire on the inside of the posts to prevent pushout.
-Steve "The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein |
Like a previous poster noted, it should be screwed on the "threat" side. Does your drywall supplier stock this? A metal supplier will have expanded metal, and less likely, flattened expanded metal. What is normally used for security screen is punched. But a well flattened expanded should work in a pinch. Expanded metal is much thicker than it needs to be, and will give you nothing but problems.
Carpenter
Can it be cut with a non motorized tool? This is a finished office setting and would like to minimize sparks, residue, dust. Cutting outside is possible but not convenient.
Capra aegagrus
Re: Expanded Metal In Security Wall? |
#7 | |
Re: Expanded Metal In Security Wall?Quote:
And punched security screen is much more expensive than expanded metal. Expanded metal has no manufacturing waste, while punching has a huge percentage weight manufacturing loss
Trade: Carpenter/GC
Rizzo,
If you're still looking for your metal or source. Look at this site or places like it for possible materials http://www.mcnichols.com/ |
| The Following User Says Thank You to Aframe For This Useful Post: | RizzoMaryland (04-20-2009) |
Trade: Construction management/General contractor
are they making you put studs on 12" centers too?
#12 | |
Commercial Contractor
Screwed to "Threat" side with fender washers, and cut with either grinder w/ metal cutting blade (I stock Metabo personally), or as long as it's 12g or lighter, you can get away with snips or dykes.
I'm doing a communications chain right now all throughout in MD & NOVA, and all the storage rooms must be this way. It's not too bad once you get a rhythm going. Few years back we did 80,000sqft of 8G wire in a hospital, That job sucked. Good Luck Rizz
Carpenter
No 16" o.c.
#14 | |
Carpenter
I understand why fasteners should be used on the threat side but at the same time it seems counter intuitive to provide access to the fasteners on the threat side. What keeps the "threat" from removing the expanded metal after drywall is ripped away?
Perhaps the goal in that sort of instance is to make it remarkably inconvenient to go through the wall. High security walls often have a security alarm wire run at 12" or 6" centers through the stud bays. Cut the wire, alarm goes off. I had to do that for a gun store in a mall in the common walls.
#16 | |
Carpenter
IMO this is certainly more difficult than ripping drywall away until the fasteners are revealed and simply removed.
#17 | |
One of these Milwaukee metal cutting saws works well, near factory edge, no sparks. I have one I have used for corrugated metal. http://www.amazon.com/Milwaukee-6370.../dp/B0000WUQI4 |
| Steel framed wall to Stick Framed Wall | Agolk2 | Construction | 2 | 09-07-2008 04:50 PM |
| wall panel around bullnose | kevbo | Finish Carpentry | 2 | 08-30-2008 09:04 PM |
| Attaching Flat Screens To Metal Stud Wall | Tidewater07 | Low Voltage | 15 | 05-04-2008 09:18 AM |
| Metal Wall Panels for decor as wainscot | pshammond | Painting & Finish Work | 10 | 04-02-2006 11:00 PM |
| Metal stud wall and door frame ? | MinConst | Construction | 8 | 10-28-2005 01:22 AM |
