Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Construction > Commercial Construction
Old 05-25-2009, 08:26 AM   #1
Trade: general residential
brick wall renovation or coverup
I have a project in Madison Indiana that needs some serious attention. It is the side of a building which is a brick wall that is 40' tall by 120, long. A young artist was commissioned to paint a extremely large mural on the entire wall. At some time ago, maybe 15 years some one stuccoed the wall with a cementisous product, probably with cement mortar and sand mix. The stucco is loose and falling off. The application was simply to trowel on the stucco in 2 coats. The brick are soft and detraining. I can only think of a few solutions which are. Mechanically fasten wire and expansion bars then apply a true stucco mix, Fasten 2x4 to the wall then apply marine grade plywood or a smooth metal siding or the dryvit system. Patching the wall with the same existing system does not seem practical because the other one failed. The young artist is the daughter of close friend whom I'm trying to help. I live 2.5 hrs north and am a General Contractor with several years experience in the Masonry and Carpenter trades. I’m just searching for something I may have missed your professional input would be much appreciated, Thanks
rusty2010 is offline   Reply With Quote
Historic Brick Fireplace Tommy C Masonry 11 10-04-2009 09:33 PM
Brick ledge coupe33 Masonry 14 01-12-2009 06:55 PM
Brick wall reinforcing Haydin Masonry 6 12-29-2008 09:58 PM
Wall papered brick wall repaint sparehair Painting & Finish Work 1 12-28-2008 08:01 PM
How to attach drywall to brick wall Mwcop1 Drywall 43 09-18-2008 10:35 AM
