Anyone Done Airport Driveway?
Old 05-04-2009, 09:07 PM   #1
Samsoon's Avatar
Trade: Main Contractor
Any subcontractor to recommend to do Airport's driveway (New and maintenance)?
Samsoon is offline
Old 05-04-2009, 09:21 PM   #2
knucklehead's Avatar
Trade: Framing,Remodeling,General Contractor
Re: Anyone Done Airport Driveway?
I will do it.
NKLHD
knucklehead is offline
Old 05-05-2009, 09:28 PM   #3
cleveman's Avatar
Trade: custom home building
What is the difference between an airport driveway and a bus station or train station driveway? Must be they call for more fly ash? Curious minds want to know.
cleveman is offline
Old 05-05-2009, 09:52 PM   #4
K2's Avatar
Propellers can hit the taxi way if there are dips or pitch changes.
K2 is offline
Old 05-05-2009, 11:23 PM   #5
Sean
SLSTech's Avatar
Hmmm, no location which might be a small factor
What are you landing on it - Learjets or a 777, that will affect the depth of the concrete, blah, blah, blah
Check with the airports around for who did the work, does the maintenance, it might even be public record depending on who runs it
Edit: By the way they are normally called Taxiways &/or Runways
Driveways are for houses, where cars are parked on them
SLSTech is offline
Old 06-16-2009, 10:22 PM   #6
Estimator/Wife/Mother/VP
Memo's Avatar
Trade: Commercial Waterproofing & Caulking
Also called the "flightline". In my line of work the materials all have to be chemical resistant...you know, jet fuel burns pretty hot. (besides the thickness of the surface.)
One other think we had to do in AF was do FOD walks (foreign object damage). The surface has to be smooth and level. Don't want no million dollar super suckers throwing an engine.
Memo is offline
Old 07-13-2009, 06:01 PM   #7
RumseySupply's Avatar
Trade: Rebar and lumber by the truck
Well, when the time comes give me a call for your material needs, especially rebar. I can save you a ton of cash, plus I would get a kick out seeing this project!
RumseySupply is offline
Old 07-20-2009, 09:09 PM   #8
poisonfangs's Avatar
Trade: carpentry
The FAA as well as local offices have strict codes for runways/taxiways. A company I work for used to handle the united airlines contracts for O'hare INT'L in chicago.
poisonfangs is offline
Old 07-20-2009, 10:53 PM   #9
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
FOD walks are fun. Did them a few times on a Boeing project. If this a commercial airport there will be alot of inspectors working for the different interests inspecting before concrete is poured. Then even more before the product is bought off.
JustaFramer is offline
Old 07-20-2009, 11:01 PM   #10
BobsLandscaping's Avatar
Trade: Landscaping
That would be bad right?
BobsLandscaping is offline
Old 07-21-2009, 02:09 AM   #11
jomama's Avatar
Trade: Concrete & masonry
That would sum up what I was going to say. Did some work a few years ago at an International, commercial airport & the FAA inspectors had to approve any gas pains. We were actually just pouring an interior floor for a stupid equipment building (maybe 7-8 yards of concrete) & they specified a slump between 2-4". Seemed simple enough, first load comes at 4.5" = rejected. Second load comes at 1.5", they ask me if I want to pour it, I say not really because we cant add any water on site = rejected. Third load, everyones getting uptight, the FAA inspectors are now poised to test temperature, as they think the plant might be trying to send out the same batch (I forgot to mention the conc. supplier sent out a salesman with 10 gallons of water reducer to add to the second batch after it was rejected, large pizzing match ensued), finally the third load hit the marks. THe stupind thing is, the driver could have sit outside the grounds, checked his slump, & added water as necessary without anyone knowing. Regardless, it's like most government operations, a lot of waste, a little bit of progress. Preaty disgusting, actually, if you have any kind of work ethic IMO. In all fairness though, the FAA inspectors were alright guys if you got on their good side.
jomama is offline
Old 07-21-2009, 02:52 AM   #12
Handle It!
MALCO.New.York's Avatar
FOD IS Foreign Object Debris until it does the deed. Then it is Foreign Object Damage!
Ultimate Wisdom---------
MALCO.New.York is offline
Old 07-21-2009, 03:01 AM   #13
Handle It!
Originally Posted by SLSTech View Post
Edit: By the way they are normally called Taxiways &/or Runways.
Sooooooooooo...........
If you park a car on it..........Why is it called a Driveway??
And..........
If you drive a car on it...........Why is it called a Parkway???
Could not find Carlins Original..........
+ YouTube Video
http://www.youtube.com/watch?v=uhW04XnXLLY
Old 07-21-2009, 07:18 AM   #14
Sean
SLSTech's Avatar
And..........
Welcome Back
Dyslexic Architect or Civil Engineer came up with the terms, probably after a few beers to show he was one of the guys...
SLSTech is offline
Old 07-21-2009, 07:37 AM   #15
Handle It!
Welcome Back
Back.............Been busy Orchestrating Events and Working.......Too Much!!!
Old 07-21-2009, 07:46 AM   #16
Sean
SLSTech's Avatar
Good to hear
SLSTech is offline
Old 08-17-2009, 11:09 PM   #17
Astrix's Avatar
Trade: Insurance Broker - Commercial Construction
Important to note re this kind of work is that airport and airside work is a big EXCLUSION on general liability insurance policies. You can't even get a standard policy extended for an electrician to change a lightbulb in the magazine shop in the airport's passenger area. You'll have to get separate insurance through a specialty insurer that writes aviation insurance.
If it is a big international airport, odds are they have their own Wrap-Up Liability Policy in place which will cover any and all contractors and trades that come on site to do work, from bigger renovations/additions to small repairs. (They know it is a problem to get insurance.) Whenever you see the "A" word, you better check with your insurance agent/broker first to see if the airport you want to work at has a Wrap-Up in place, and if not, how much extra $$$ it is going to cost you to buy the separate aviation policy.
Astrix is offline
Old 09-12-2009, 03:53 PM   #18
Division 8 pro
Haaser's Avatar
i know this is a month old, but i cant help myself!!!
STAY AWAY!!!!
Airports SUCK!!!
there is SO much you need to deal with.. FAA, DOI, State Fire Svcs. not to mention all the security. we worked on the RDU airport a few years back... we had ho hire people that could pass the checks just to escort the labor that could not pass security checks...
But on the upside its a good way to weed out guys using stolen ID's... HAHAHA... they all quit on the spot...
"Don't be a fool and die for your country. Let the other sonofabitch die for his." ~ Patton
Haaser is offline
Old 12-18-2009, 05:56 AM   #19
Asphalt Repair Specialist
johnmwentz's Avatar
Trade: Asphalt Surfacing & Repair
Thats so typical. I generally donot prefer gov. contracts because of the high-handedness of gov authorities.
johnmwentz is offline
Stamped concrete or real stone pavers in driveway? uridixsento General Discussion 1 04-27-2009 07:15 AM
Best base for concrete driveway paintguy Concrete & Paving 8 02-14-2009 10:53 PM
Pouring new driveway on top of old driveway Brock Concrete & Paving 8 12-01-2008 04:39 PM
bonding agent for stone driveway rocknhammer Specialty Trades Picture Post 5 09-28-2008 07:25 PM
Someone used my driveway without permission Sportbilly General Discussion 40 03-02-2008 09:56 PM
