Stupid Question About Drain Holes In Built Up Walk
Old 03-26-2007, 07:03 PM   #1
Jacey's Avatar
Trade: Landscape
Hey~I have a home owner who refuses to let me buildup the dirt in a recessed area flanked by walkway that is a good 7 inches empty because she thinks the 3 inch drainhole at that depth will not drain if I do so. I am a landscaper and have never seen a situation like this where you couldn't build up the interior, but she has me worried as she seems like she could turn into a problem customer if by any chance I am wrong here. I thought about throwing crushed rock in just in case..anybody out there know the answer to this?
Jacey is offline
Old 03-26-2007, 08:17 PM   #2
tgeb's Avatar
Re: Stupid Question About Drain Holes In Built Up Walk
Unless you can convince her that what you will be doing is 100% proper and can put her at ease with the work, I would have to refer back to the old saying "The customer is always right"
Do as she requests.
www.gebcon.com
tgeb is offline
Old 03-27-2007, 01:23 PM   #3
Jacey's Avatar
Trade: Landscape
Ok..maybe I overstated the refused to part..she thought because the last owner never filled over that depth, she couldn't either. I had a rock mason here with 40 years experience that just shook his head and said..not a problem..it will drain perfectly. Unfortunately this homeowner has turned kinda bi-polar on another subject..so not wanting to give her any possible source of added anxiety..still wanting not to give in to the no brainer aspect..if indeed it is obvious to you guys who do this for a living. Would like at least one more qualified opinion. I mean everything slopes away from the house..the walk is elevated with a hole going horizontally to the other side where it spills out onto the lawn. I have done french drains and know there is another way..but don't want to add to the expense as we are locked in on the bid.
Jacey is offline
Old 03-28-2007, 07:14 PM   #4
tgeb's Avatar
If as you say it will drain "perfectly" and there is no other issue such as grading above a foundation vent, window, weep holes in a wall or raising the grade too close to wood framing of the house, I'd say go for it.
www.gebcon.com
tgeb is offline
Old 03-28-2007, 07:20 PM   #5
Teetorbilt's Avatar
Let her talk to the guy with 40 yrs. experience. Trust me, gray hair/baldness can sell. I'm gray.
Albert Einstein
Teetorbilt is offline
Old 03-28-2007, 08:29 PM   #6
dirt diggler's Avatar
Trade: contractor
what do you sell Teetor?
dirt diggler is offline
Old 04-01-2007, 04:53 PM   #7
Jacey's Avatar
Trade: Landscape
Hey Thanx guys..didn't see your replies til after I bit the big one and just went on and did it..day before the sky opened the people even had water coming into their house from the back...but my little bed stayed put..WOW..am I proud. Final check for 8 grand in my pocket and I'm
Jacey is offline
stupid question stacker Masonry 21 07-01-2009 09:42 PM
built up slab question stampcrete Concrete & Paving 9 03-27-2008 05:24 PM
Condensate drain question airwick HVAC 6 07-23-2007 07:48 PM
French drain question 72chevy4x4 Construction 4 11-01-2006 10:46 PM
Stupid question RobertCDF General Discussion 13 02-19-2006 11:11 AM
