Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Concrete & Paving
Old 07-07-2009, 12:30 PM   #1
Trade: installer
staining concrete
Me and my friend are about to try our first stain concrete on my garage which has really bad oil stains pretty dark. I know i need to put a big dent in getting these dark grease stains out to have a good floor. Whats the best solution out there to buy to help removing these stains.
jhontexas is offline   Reply With Quote
Old 07-07-2009, 12:56 PM   #2
KCCT's Avatar
Trade: Concrete Restoration
Long story short, the acid isn't going to react in those areas, along with anywhere that has seen armor all, flux, ect.
KCCT is offline   Reply With Quote
Old 07-07-2009, 01:01 PM   #3
Trade: installer
So would it be best just to put a overlay then Stain?
Old 07-07-2009, 01:08 PM   #4
KCCT's Avatar
That would be the best solution. Even new concrete is sometimes a b*tch to acid stain. I just wrapped up a 4500 sq ft job that was a new pour & had a 7 day deadline. I ended up using MEK based dye instead of acid to keep the "suprises" down to a minimum. Even using the dye its amazing what shows up when its sealed.
Old 07-10-2009, 09:14 PM   #5
6stringmason's Avatar
Trade: masonry
Even with overlay you may still need to prep the floor. Depending on what product you use. Some overlays you cant even buy unless you've been trained. In my area anyway.
Overlay would be your best bet though. There are many good self-leveling overlays out there that take acid stain well.
Kamps Masonry & Concrete Countertop Design
920-680-3195
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is offline   Reply With Quote
Old 07-17-2009, 07:47 AM   #6
Tile and Stone Cleaning
Trade: Tile and Stone Restoration
This works very very well:
(I cannot post link for product with my post count -- type in prosoco oil remover into google)
It will not be good enough for an even acid stain though.
brzelt is offline   Reply With Quote
Tags
concrete restoration, grease stains, stained
Staining Concrete Bentz34 Masonry 1 04-13-2009 04:15 AM
Staining concrete ryan.s Masonry 12 03-05-2009 03:54 PM
Advice - concrete Pool Deck coping ejleonard Masonry 4 06-17-2008 04:18 PM
Need advice! Staining concrete with Border Guardi Pro Painting & Finish Work 6 10-30-2007 02:04 PM
