Slab Patch Failure
Old 08-12-2017, 03:09 PM   #1
artinall's Avatar
Trade: Fix It & Remodel
Rewards Points: 1,684
Slab Patch Failure
The contractor who did this said they used hydraulic cement patch.
Raved about it.
But I don't think they did anything as far as reinforcement -- the patch is about 8 to 9 inches across and the front center of the pocket door rests on (metal 'U' brace) in addition to being fixed at a right angle wall from behind (4 to 5 inches back). Formerly it was a pvc vent pipe that was relocated. This patch was let to dry/cure for more than 2 mo's before started doing this...
What does this look like - too rich a mix? No structural reinforcement below? No wetting of the concrete edge to encourage a bond at the perimeter?
What might be a recommended repair method? As it is, I cannot lay our tile, will surely crack out.
artinall is offline
Old 08-12-2017, 04:41 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 3,488
Re: Slab Patch Failure
In my world we would square up those edges, square up the sides, make certain ALL loose material is removed from the patch area.
The patching material you are going to use will determine the next steps.
You may have to fool with depth and provide a bonding agent.
Why did yours fail????
wrong material, too much water, not clean, improper prep etc....
griz is offline
artinall (08-13-2017)
Old 08-12-2017, 11:36 PM   #3
Designer/Contractor
Rio's Avatar
Rewards Points: 1,708
I would do something along the lines of what Griz said and then put an anti fracture membrame of some sort over the concrete in that area. As long as there isn't any differential settlement I would think you'd be good to go, stressing the word think.
Rio is online now
The Following User Says Thank You to Rio For This Useful Post:
Old 08-13-2017, 07:47 AM   #4
artinall's Avatar
Anti fracture membrane? If under that door, then not only the pocket door but that wall would have to be reframed.
Already I planned on putting ditra down for the tile. This can't fail, if it were to then the entire ditra layer might have to be pulled, which floats in a layer as I understand it, which means everything in this small bath?
Might that pocket door have to be yanked, to get an even repair?
artinall is offline
Old 08-13-2017, 09:32 AM   #5
tgeb's Avatar
Rewards Points: 750
Hydraulic cement is not really a good product for patch work like that, great for plugging holes and small cracks, not so much in lager areas.
I would have used a simple high strength bag mix and maybe a little bonding agent.
But like Griz mentioned the perimeter needs to be cleaned up.
Tear that patch out and clean cut the sides, square up the hole. 5,000 psi sakrete mixed tight and you should be good to go.
www.gebcon.com
tgeb is offline
The Following User Says Thank You to tgeb For This Useful Post:
Old 08-13-2017, 10:47 AM   #6
artinall's Avatar
What would you use to square sides on this smaller hole, with the wall obstruction?
artinall is offline
Old 08-13-2017, 10:59 AM   #7
Fire up the BBQ
griz's Avatar
Roto Hammer and a 4" grinder.
We do it all the time.
griz is offline
tgeb (08-13-2017)
Old 08-13-2017, 04:52 PM   #8
Quality5280's Avatar
Trade: Hardscape ,Landscape and Roll off Containers
Rewards Points: 134
Looks like they broke it out with a sledge hammer and patched right over the rough edges
Cut it out with a demo saw and rep our it with 4-5000psi bag mix
Sent from my iPhone using Tapatalk Pro
Quality5280 is online now
Building Deck over Slab....? SailingandSuch Decks & Fencing 18 12-17-2014 11:30 AM
Advice on fix of poor finish on Concrete slab Aframe General Discussion 6 12-07-2014 03:41 PM
DIY knockdown patch Cole82 General Discussion 9 05-27-2012 11:44 PM
Cement backer board over concrete slab gtimk4 Flooring 14 12-21-2010 08:46 AM
Installing a Door Slab CookeCarpentry Finish Carpentry 62 07-11-2010 07:23 AM
