Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Concrete & Paving
Old 07-12-2009, 05:21 PM   #1
Trade: General and Tile
Question sidewalk repair
Hi, I need to level a 15" wide x 4 foot section of sidewalk that settled about 1/2 an inch after being saw cut to lay pipe and then re-poured.
I tried an overlayment repair cement from Lowes, but 2 weeks later it just cracked and came loose with a slight blow.
Any suggestions for another material?
Thanks, Ken Owens
KenCharles is offline   Reply With Quote
Old 07-12-2009, 05:26 PM   #2
Sean
SLSTech's Avatar
Mud Jacking
SLSTech is offline   Reply With Quote
Old 07-12-2009, 05:44 PM   #3
dkillianjr's Avatar
Tree fiddyin
"Pay now or Pay later"
dkillianjr is offline   Reply With Quote
Old 07-12-2009, 06:14 PM   #4
Thom
thom's Avatar
I think the mud jacking idea is the way to go. The $20thousand set up charge should be way cheaper than buying 2 or 3 bags of quickrete.
In my town (Albuquerque) anyone who works on a city sidewalk is required to have a minimum $2million bond with the city. Ask your mud-jacker if he charges more for bonded work. That $20,000 price may be a bit low.
thom is offline   Reply With Quote
Old 07-12-2009, 06:20 PM   #5
A.A.O.N.M.S.
Jesse Kirchhoff's Avatar
Trade: Commercial Handyman Services and Entrepreneur
We have used a small car jack to lift the sidewalk and punched sand underneath with a 2x4 scrap in the old days.......now we tear it out and re-pour. A couple hundred dollars in material is more cost effective than a bad reputation.
Good luck
Jesse Kirchhoff is offline   Reply With Quote
Old 07-12-2009, 06:32 PM   #6
cleveman's Avatar
Trade: custom home building
Remove and Replace 60 square feet=$240.
cleveman is offline   Reply With Quote
Old 07-12-2009, 06:36 PM   #7
Home Depot aisle walker
willworkforbeer's Avatar
Trade: home remodeling
Thanks, Ken Owens
15" x 4' is about 5 sq ft, right people?
willworkforbeer is offline   Reply With Quote
Old 07-14-2009, 10:24 PM   #8
Twisted Cameron
Trade: Concrete, Metal buildings
You can come do all the concrete you want for me! ha, 4 dollars to remove and replace 60 square feet at 240= starving wages. if its not a lot of walk you can use a spud bar or hammer a few stakes under it to lift it to where you want, remove a little dirt on the side of it, and push sand under it, should work like a champ.
scrapecc is offline   Reply With Quote
Old 08-17-2009, 09:17 AM   #9
Trade: concrete,landscaping
Kemosaby,remove damaged area (15"x4').Dowel into old sidewalk (holds new in place).Repour area,that 1/2 ain't beens,problem solved.
many names is offline   Reply With Quote
Tags
ken
counter top repair? te12c02w General Discussion 7 03-23-2009 08:44 AM
Rheem Recalls to Repair Oil-Fired Furnaces Due to Fire Hazard MechAcc HVAC 0 01-22-2009 06:10 PM
how to repair interior cement plaster mark_2222 Painting & Finish Work 3 11-25-2008 12:30 AM
Tool repair service bert0168 General Discussion 4 10-22-2008 12:43 AM
Sidewalk Repair tate16t Masonry 3 08-15-2008 09:02 AM
