Seeding Concrete
Old 06-13-2009, 12:23 PM   #1
kcreinke45's Avatar
Trade: Concrete Polishing
Seeding Concrete
Hey guys I do concrete polishing and have a customer who wants to seed the slab with marble chips, and then have me come in and polish it. I am not sure if his concrete guy is up to the task, has anyone done this that knows the proper procedure? Thanks
KC
kcreinke45 is offline
Old 06-15-2009, 01:34 PM   #2
gallerytungsten's Avatar
Trade: Design
Re: Seeding Concrete
If you check the Cheng book "concrete in the home" you'll find a description of the process.
gallerytungsten is offline
Old 06-16-2009, 06:56 AM   #3
kcreinke45's Avatar
I am sorry if I did not make myself clear, this is not a counter top, I am talking about seeding a 12,000 sq ft. building slab, which will than be polished.
KC
Old 06-16-2009, 05:41 PM   #4
Trade: Design
Cheng has two books; one for counter tops and another for various concrete applications, including broadcasting color chips; as noted, it's called "concrete in the home."
Old 06-16-2009, 06:26 PM   #5
concretemasonry's Avatar
Trade: Masonry consultant
It sounds like you are looking for something similar to terrazzo, where the expensive aggregate is cast and worked in to minimize the high cost of imported aggregates that grind well.
Because of the size of aggregate desired for appearance, it is first ground to expose the larger faces and them polished. - Not speedy and requires experience and patience.
Dick
concretemasonry is offline
Old 06-18-2009, 11:33 AM   #6
celtic
Taranis's Avatar
Trade: Flooring
Big issue with doing it this way is getting the concentration of aggregate consistent through the floor. One of our suppliers came up with this idea instead of using the normal resin terrazzo but was utter garbage.
Taranis is offline
Spalling concrete stabilization tsunamicontract Concrete & Paving 4 06-07-2009 08:51 PM
I need a to pour 1/4 yard of black concrete... ruskent Masonry 9 05-25-2009 12:50 PM
Concrete stain problem Forry Concrete & Paving 6 09-02-2008 09:10 PM
Advice - concrete Pool Deck coping ejleonard Masonry 4 06-17-2008 05:18 PM
