Sealing Pebble Over Concrete Patio
Old 10-19-2007, 03:16 PM   #1
Fireplaces Plus's Avatar
Trade: Fireplace Installation
Hello, I am in need of help. I purchased a home approximately two years ago that has approx 1000 sf of patio. It is a four inch slab with 1/4'' pebbles, I assume, expoxied. I need to clean and reseal it. Can anyone help? Please email me at accounting@fireplacesplusinc.com. Thanks
Fireplaces Plus is offline
Old 10-24-2007, 02:26 AM   #2
DREWALAN3's Avatar
Trade: CONCRETE CONTRACTOR
Re: Sealing Pebble Over Concrete Patio
First You Will Need To See If It A Water Base Sealer Or Solvent. The Rest Is Easer Done Than Said But You Sound Like You Already Know The Rest Of The Steps Contact Me For Details If You Need Help Stripping The Sealer Or Just And Easy Reseal.
DREWALAN3 is offline
Old 10-24-2007, 04:22 AM   #3
celtic
Taranis's Avatar
Trade: Flooring
My tuppence worth is this. Pressure wash the area, may need to be done more than once. Let it dry, then solvent wash the area (Use paint thinners, not turps or white spirit) by puring it on the floor and with a rag over a soft broom coat the pebbles. This will open up the surface ready for a new coat. Then use and epoxy, or if it is a light coloured pebble you may need to use a UVR polyurethane or acrylic resin. Leave to cure dependant on which resin is chosen. You may need to get a contractor specialising in this material.
Taranis is offline
Old 10-24-2007, 06:52 AM   #4
Captain of the Titanic
Vinny's Avatar
Trade: Asphalt Paving,Excavating, Masonry
There was another post in here, somewhere, that talked about a simalar issue. One poster said he was an expert and said to basicly clean it and cover it witha clear epoxy again.
Look around he is in here somewhere, he seemed to know what he was talking about
Roccies Asphalt Paving
The Right Way Driveway Company
If you say you cant, your a loser. If you say you wont, your a quiter. Which one do you want to be?
Vinny is offline
Old 10-24-2007, 08:47 AM   #5
carolinaprowash's Avatar
Trade: Exterior Surface Specialists
You can contact this gentleman: www.mckinnonmaterials.com He sells a system similar to what you're describing Very nice folks there!
Celeste
Carolina ProWash
Graham, NC 27253
336-270-4598 Office
336-516-6139 Roger 336-516-6356 Celeste
carolinaprowash is offline
Old 10-27-2007, 01:00 PM   #6
cabook's Avatar
Trade: decorative concrete coatings/garage floor coatings
FIREPLACE PLUS,
Contact me I may be able to help you.
E-mail: cabook35@hotmail.com
cabook is offline
Old 10-27-2007, 11:09 PM   #7
DREWALAN3's Avatar
Did Not See The Word Epoxied In There.
Old 10-30-2007, 01:10 PM   #8
celtic
Taranis's Avatar
Trade: Flooring
Fireplace, epoxied is a past tense verb, not a material. It's not a term we would use in the industry but I know what you mean. For your info epoxy is one of a number of resins available (there are a number of different epoxies and epoxy systems on the market). Some others are polyurethane - more an industrial resin, acrylic - MMA a hard and sometimes brittle plastic and the aliphatic one that cabook mentions. The last two cure very quickly but there are pros and cons of all the resin systems in use. That's why there are many different types. By the way cabook, some epoxies and PUs are UVR too.
Ask a contractor close to you for information, as long as he doesn't just do the industrial applications he would be more than happy to help you decide which is best for you. Would be happy to show his experience. You normally won't get a cowboy as anyone that says they can do resins will easily be found out if they can't.
Taranis is offline
Pebble based patio highlife77 Masonry 9 10-23-2007 10:04 PM
Outdoor patio concrete overlay joesauers Masonry 1 02-17-2007 08:38 PM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
Sealing concrete countertops 6stringmason Masonry 2 12-12-2006 09:07 PM
