Removing All Thread From Monument Pours - Concrete & Paving - Contractor Talk
Old 01-20-2012, 12:48 AM   #1
Brownchickenbrowncow
elementbldrs's Avatar
Trade: General Building
Rewards Points: 1,376
We have poured several monument pours for a client that we used all thread for ties... wanted to remove them while green to minimize grout hole due to stamp texture integrated into forms (simple OSB look) for post modern house.
Well as you can guess we cant remove them now. Wished we woulda greased them but everyone had ideas and here we are now. Tired to double nut and back em out, just snaps them. Same with pipe wrench.
So have about 3 dozen 1/2 inch diameter 2 inch all thread stickin out with sensitive textured concrete.... ideas???
elementbldrs is offline
Old 01-29-2012, 12:44 PM   #2
Nac's Avatar
Trade: Concrete, masonry & excavation
Rewards Points: 324
Re: Removing All Thread From Monument Pours
Good luck if you find a way let me know. Normally we sleave the tie with a pvc pipe or just use a she bolt.
Facebook
Nac is offline
Old 02-05-2012, 07:54 PM   #3
Cuda's Avatar
Trade: Drainage, Waterproofing & Sewer Contractor
Rewards Points: 214
5/8" or 9/16" cheap oversees core bit and fill? Plasma Cutter and pierce them down 1/2" and fill.
Cuda is offline
Old 03-24-2013, 06:40 AM   #4
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
Thats exactly what i would do, cut a pipe to your poured thickness, and there ya go, spacer and room for the tie.
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Old 03-24-2013, 01:52 PM   #5
Hindsight is 20/20 my friend. I woulda just used snap ties and been cool. But too many chiefs.
I might try the plasma cutter.
Phil
Old 03-24-2013, 02:58 PM   #6
rustyjames's Avatar
Rewards Points: 1,586
Carbon Arc Gouging might work too.
Edited to add that the carbon arc ain't going to get it unless the rods are tied to a rebar cage. No ground, no worky. Although if you clamped what's sticking out and give it a blast with the carbon air arc, it might get you below the face of the wall to patch it.
rustyjames is online now
Picture thread of MOST BRUTAL workmanship JT Wood General Discussion 73 09-15-2010 10:37 PM
Thread closed - Excuse me gwiffy Site Feedback and Suggestions 8 07-29-2010 10:20 PM
Removing concrete corner blocks!! Nail Ace Masonry 3 04-16-2010 09:53 PM
Removing studs from a load bearing wall. Russ25nys Framing 36 06-13-2009 08:52 PM
