Rebar Or Wire Mess In A 4" Slab?
Old 01-20-2008, 04:10 AM   #1
tikicarver's Avatar
Trade: electrician
I was reading another forum were several guys were saying they never use rebar in a 4" slab. Then others said it was much easier to keep rebar centered in the slab during the pour.
I'd be interested to hear what others do.
tikicarver is offline
Old 01-20-2008, 11:28 AM   #2
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Re: Rebar Or Wire Mess In A 4" Slab?
Depends on engineer specs...
Earthquake country everything is rebar here
Mesh if your not watching the guys will squish it down under the pour rendering it useless, rebar if pushed down is easier to lift and get back into the mud where it belongs.
Chris
Chris Johnson is offline
Old 01-20-2008, 12:54 PM   #3
Remodeler Extraordinare
A.W.Davis's Avatar
Rebar here in Cali
A.W. Davis Construction Co.
http://www.awdavisconstruction.com/
Your friendly remodeling contractor
A.W.Davis is offline
Old 01-20-2008, 01:27 PM   #4
Al Smith
A W Smith's Avatar
Ive never seen rebar in a four inch slab on any jobs Ive done over the years. Always WWF that we pull up with a rock rake.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 01-20-2008, 01:36 PM   #5
A.W.Davis's Avatar
Theres clearly a variation in how the east coast and the west coast do things.
Here in Cali we use rebar set on "dobies" and tied together in a staggered pattern.
I have seen sidewalks "buckle" in the summer from high heat. We had a job like that last summer.....turns out upon demo of the sidewalk it had the wire gridding in it instead of rebar.
Old 01-20-2008, 01:44 PM   #6
Al Smith
A W Smith's Avatar
We call "dobies" "chairs".. Are you using #3 rebar or #4? or pencil rod?
Saw your sidewalk example edit
A single layer of reinforcement will not prevent a sidewalk from buckling as they do not run through the expansion joint. Expansion joints must be at a minimum 10 feet apart for sidewalks to prevent that heat buckling. But if it happened in a crack in the slab you would need to set your reinforcement staggered on double height chairs to prevent that.
Al Smith
Old 01-20-2008, 02:15 PM   #7
A.W.Davis's Avatar
It all depends on what we are doing and the spacing of the rebar grid. Usually we use #4 rebar at 12" o.c. so we dont have to tie as much.
Never heard of chairs before. I am old fashioned I guess and would probably still prefer concrete dobies. Just my .02 cents
Old 01-20-2008, 02:35 PM   #8
Yeah, back here we kind of expect our ground
to stay still and not get the heebie-jeebies.
4" slabs get 6-6-10-10, and the little thumb "thingy"
on the back of the come-a-long pulls it up as you pour.
Are "dobies" what we call concrete brick?
That's what we lay mats on.
I've never used chairs except for deck pours.
neolitic is offline
Old 01-23-2008, 03:19 PM   #9
Mod / ArchiBuilder
Cole's Avatar
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
Cole is offline
Help Installing Hardwood over old/new Concrete Slab Hages Flooring 7 06-04-2008 01:02 PM
built up slab question stampcrete Concrete & Paving 9 03-27-2008 05:24 PM
Wire balustrades karma_carpentry Decks & Fencing 11 09-17-2007 06:10 PM
Demo a foundation under a radiant heat slab without disturbing the slab...? wackman Remodeling 18 04-02-2007 12:38 AM
safe hot wire driver Electrical 13 05-12-2006 11:18 PM
