Pouring An 8x12 Concrete Slab Foundation For Shed - Frost Heave A Concern?
Old 11-30-2009, 08:51 PM   #1
Panzer5's Avatar
Rewards Points: 254
New Question: (12-11-2009) See Post # 7
I plan on pouring a slab foundation for an 8x12' shed I'll be erecting soon. The ground in the area we intend to put the shed appears well drained. The HO is really concerned about frost heave - although he admits to never having had any frost heave problems before; nevertheless, this is Kentucky & we do get freezing weather...
My plan was to dig about 7 inches down, back fill with gravel compacted to 4 inches & pour a slab 4 inches thick (thicker at the edges). I figured frost heave likely wasn't a problem, given the size of the slab & condition of the ground - but wanted to ask before I got started anyway...
Am I right thinking that frost heave isn't a concern for this structure? if not, would using concrete tubes & pouring 24" footers at the corners & at about 6' down along the edges of the length be sufficient?
(While I've helped pour sidewalks, etc. - this is my first foundation as the contractor where I've got to do the planning as well as the execution!)
Scott (the ex-grunt-tanker-jarhead guy)
Panzer5 is offline
Old 11-30-2009, 09:26 PM   #2
tgeb's Avatar
Rewards Points: 250
Re: Pouring An 8x12 Concrete Slab Foundation For Shed - Frost Heave A Concern?
If this is to be a free standing structure, (not attached to any other building), I would not be too concerned about frost heave.
If frost does affect this, it would most likely affect the entire concrete pad, lift it uniformly and return it to its original location uniformly.
If you want to add some strength to this, a "turn down" edge at the perimeter with a couple pieces of rebar will do a lot with little cost.
That being said, I don't know the weather extremes there in KY. We will soon be doing a storage building with a monolithic slab/footing, 16 X 32 building that will have footings to below frost line. Better safe than sorry.
If the client has concerns and is willing to pay to have the footing, I would do a frost depth foundation.
If you talk him out of the foundation and there are problems later.....you will get the blame.
www.gebcon.com
tgeb is online now
Old 11-30-2009, 10:39 PM   #3
DavidC
DavidC's Avatar
Rewards Points: 2,006
Frost heaves are a concern in my area, we have to put our footings at least 48" below grade.
However, plenty of garages and sheds are built on floating slabs without problems. 12" thick around the perimeter, 8" wide on the bottom and taper to 4" thick slab. 2 continuous rebars around the perimeter with mesh embedded in the whole thing.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 11-30-2009, 10:46 PM   #4
Dave from Macatawa
macatawacab's Avatar
Trade: GC, cabinet maker and remodeler
Rewards Points: 250
Here in MI we can do free standing up to 400sqft monolithic with turn down minimum 12" below grade just like David C posted
macatawacab is offline
Old 11-30-2009, 11:30 PM   #5
solar guy
naptown CR's Avatar
Trade: solar contracting
Rewards Points: 1,000
Yeah what they said
I wouldn't worry about it much. not for a free standing shed that size. It may lift but will settle back down again without a problem I can see.
naptown CR is offline
Old 12-03-2009, 12:34 PM   #6
Architect
CORN's Avatar
Trade: Architect
It would be better not to pour your corners below the frost line while having the mid span footing above the frost line. This could cause differential frost heaving.
CORN is offline
Old 12-11-2009, 10:25 AM   #7
Panzer5's Avatar
Rewards Points: 254
Thanks folks!
Another question: since this is my first foundation I'm not really up to speed on what type of concrete to ask for. Since temps are ranging from upper 20's to lower 40's, do I need to request anti-freeze in the mix?
@ CORN: I planned on 6 footings; one at each of the four corners & one at each edge midway down the long axis. Would that be sufficient?
Panzer5 is offline
Old 12-11-2009, 10:41 AM   #8
Rewards Points: 2,000
I'd want either continuous footings,
or no footing, just turn down the edge.
Ask the ready mix guy for calcium
and full air.
He knows what to do.
They don't use antifreeze,
it's hot water and accelerator.
neolitic is offline
Old 12-11-2009, 11:01 AM   #9
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,094
And some blankets.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 12-11-2009, 11:23 AM   #10
Architect
CORN's Avatar
Trade: Architect
I agree with the two posts above. It's important the concrete not fall below 50 degrees for the first 5-7 days.
CORN is offline
Old 12-11-2009, 01:46 PM   #11
Panzer5's Avatar
Rewards Points: 254
Originally Posted by WarnerConstInc. View Post
And some blankets.
Blankets? Like packing blankets? Or are you talking about some specialty electric blanket I'd have to rent?
Whoops... forgot to Google before I asked: This article suggests I can use packing blankets & plastic tarps. --Thanks for the tip!
Next Q: When we poured the sidewalks & steps, we had the HO water the crete for several days. Doesn't seem like a good idea here. Does spraying on a liquid curing compound (as suggested in this article eliminate the need to keep the surface wet?
Also, what's the best (low-cost) method for heating the ground / gravel before the pour? Propane heaters like this one?
Panzer5 is offline
Old 01-06-2010, 11:47 AM   #12
Rockmonster's Avatar
Trade: Masonry
Rewards Points: 5,494
Yes to your last question, although you're probably done by now....The morning after our slabs, we apply UGL masonry sealer, in water base....It is dynamite as a curing agent, since I don't usually have the time to maintain a damp cure....2 thumbs way up...
Rockmonster is offline
Old 01-11-2010, 01:41 PM   #13
Concrete Mike
CONCRETE MIKE's Avatar
Trade: concrete
Rewards Points: 250
Originally Posted by Panzer5 View Post
Thanks folks!
A good mix would be a 6 and one half sac mix with 6 to 8 percent air,blend sone, 50% no8 and 50%no57 lime stone, noncloride or calcium about one percent unless u can work fast then two percent, use blankets after pour or visqueen with straw.
CONCRETE MIKE is offline
Old 01-11-2010, 01:54 PM   #14
Concrete Mike
Trade: concrete
Rewards Points: 250
U should not seal till 28 days after cure, apply a cureing compound then seal at later date, that is a mistake alot of contrators not cement men make, read aci specifications.
Old 01-11-2010, 01:59 PM   #15
Concrete Mike
Trade: concrete
Rewards Points: 250
Make sure the base is sound and compacted, use a 57 lime stone it costs more but is one of the best.
Cracked sagging slab foundation? Project_Pat Masonry 20 06-18-2010 10:11 PM
Flagstone over slab paulbronson Flooring 2 10-26-2009 08:15 PM
Commercial Ceramic tile on concrete slab removal TD40 Tiling 4 05-27-2009 05:02 PM
concrete slab on paved drive? durham Concrete & Paving 7 09-13-2008 11:28 PM
Paint on concrete foundation? Project53 Construction 4 02-04-2007 09:43 AM
