Polished Concrete Floor & Radiant Heat
Old 05-30-2009, 11:02 AM   #1
bcbuilder32's Avatar
Trade: General Contractor - Remodels & new construction
Greetings.
This is an interior application.
I'm installing a 2" thick concrete slab over an existing concrete slab which is going to be polished. First I'll be installing radiant heating with thin set mortar, then going over the top of the radiant heat with my 2" slab and then polish. I'm concerned about the new slab only being 2" being prone to excessive cracking. Is there something I could add to the mix to minimize the cracking?
And why is the new slab only 2"? I have to match the existing floor height.
Thank you experts!
bcbuilder32 is offline
Old 05-31-2009, 12:35 AM   #2
Hoven
Hoven's Avatar
Trade: Decorative concrete / Comercial /residential flatwork
Re: Polished Concrete Floor & Radiant Heat
# 4 rebar laid on floor spaced out with flat sheet wire tied to it, fibermesh , a liquid polymer you can add right into the ready mix truck or a spray on. , or 4000 lb concrete are all options. How heavy is the polishing machine? 2in is more of a counter top thickness. I usually try to cap a min of 3in if possible so I can use the bigger aggregate. Use a straight edge to place so the grinder is grinding a flat plane rather than trying to make one.
Hoven is offline
Old 06-05-2009, 08:24 PM   #3
GC - Estimator
ebeye's Avatar
What are the specs and plans showing? isn't there any reinforcing specified already?
ebeye is offline
Old 08-25-2009, 08:40 PM   #4
michaelxslx's Avatar
Trade: Polished Concrete Floors
Hi. You might want to check out our page regarding the process. Can't post URLs yet, but it's in my signature.
Cheers!
Michael Xslx | Polished Concrete Melbourne!
michaelxslx is offline
Old 04-25-2011, 08:03 AM   #5
Marcos Shaw
m_shawry's Avatar
If you don't want cracking, then suring is very important. When the concrete is drying it is shrinking towards the middle. By keeping the moisture within the concrete you can help minimise cracking immensely.
Cover the concrete with black plastic for as long as possible.
We don't polish our slabs until at least 30 days after pouring to ensure the concrete is fully set.
m_shawry is offline
Radiant heat pipe install question im4snow HVAC 6 03-09-2011 07:28 AM
Tile over hydronic radiant heat angus242 Ceramic & Stone Tile 23 05-20-2010 10:06 PM
Ever heard of electric radiant floor heat under slab? IHI HVAC 10 02-27-2009 05:32 PM
Radiant Heat demaat HVAC 6 11-16-2008 07:52 PM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
