Patio & Spa Pad Over Fill Questions
Old 01-08-2008, 04:47 PM   #1
deckman22's Avatar
Trade: Deck Builder
I have a 8'x8' spa pad & a 12'x15' patio to pour on my next project. The back yard has a retaining wall all the way around it, 3-4' of gravel next to the retaining wall then whatever the home builder could find to fill it in. The fill is mainly dirt/limestone from what I can tell. The area where the spa pad is going to be has about 8-10' of fill & the patio/pergola has about 6-8' of fill. I plan on getting a driller to drill 16" holes thru the fill to virgin soil. 4 holes, 1 on each corner, 5/8" rebar cages w/ 18"x12" beams around the perimeter for the spa pad. Same deal for the patio except the holes will be 12' outside to outside w/ beam running 3' past the hole plus a beam going thru the center. For beams I'll have 4 - 5/8" rebar, 2 at the top, stirrups & 2 at the bottom, then 1/2" rebar 24" oc to fill in the rest of the area. My question is does that seem to be enough to support a 7'x7' spa, 350 gallons water, & 5 people max. load? Same question for the patio that will support a 12'x12' RSC pergola. Also can I pour the piers first let them set up then pour the pads over them or is it best to pour the whole deal at once? The HO is worried the typical 4" patio & spa pad would settle because of the fill. The pool builder working next door told him his yard would settle about 18" in a years time, seems a little much to me. I would post a drawing, but I'm not the most computer savy person around. Thanks for any comments.
Deckman
www.alscustomdecks.com
deckman22 is online now
Old 01-08-2008, 05:22 PM   #2
dirt diggler's Avatar
Trade: contractor
Re: Patio & Spa Pad Over Fill Questions
ok - so the area that you are placing the pad on ... let's talk about it
it has about 6 or 8 feet of fill (from when they did grade on the home's construction??) and who is telling you this??
correct?
how long ago was the fill placed?
you can beef up the pad all you want ... won't make a difference in the world if you're installing it on top of an old trash pile
2Bcontinued ...
Thanks in advance!!!
dirt diggler is offline
Old 01-08-2008, 05:53 PM   #3
deckman22's Avatar
Trade: Deck Builder
correct?
2Bcontinued ...
Dirt,
The home was completed a couple of months ago. I can tell how much fill is there by the height of the retaining walls. Also the pool builder next door has pics of the lot before backfilling.
I know that putting in more concrete & beams isn't going to solve the problem of settling. However with the piers to virgin soil up to the beams it should hold in my mind. I could hire an engineer, just trying to keep from the added expense & time factor. I do not want to waste all the time/money drilling/installing piers only to have it fail inspection. Engineer would be safest thing just the only other job I had for Jan. ain't happening. Got a sales appointment in a few minutes so that could change.
Deckman
Old 01-27-2008, 05:54 PM   #4
derek1175's Avatar
Trade: concrete construction
This plan you have will work the piers to natural soil i like go just a little deeper a foot or so the steel plan is good i like to pour peirs first pouring with the floor is ok but inmy mind all at once seems to put too much weight on the ends and may cause a crack hope i was of help
derek1175 is offline
Old 01-27-2008, 06:14 PM   #5
concretemasonry's Avatar
Trade: Masonry consultant
All the fill you see will at a lower level in a few months and there be little supporting any floating slabs and the slabs will need to be structural.
Dick
concretemasonry is online now
Pricing questions Brian Painting & Finish Work 3 10-13-2007 09:38 AM
Flowable fill? ruskent Excavation & Site Work 18 01-16-2007 06:37 PM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
Slab on Grade fill options? James Ellis Construction 10 10-24-2006 01:55 AM
Patio Expansion andy998 Masonry 6 08-20-2006 06:32 PM
