Trade: commercial gc
Patching Penetrations In Concrete Roof Deck
Looking for some advice.
I need to patch some cores, exist. curb openings, etc...in a concrete T roof deck. Want to get the best finish possible as the deck will be exposed as ceiling. Thinking epoxy based system, with form material shot up/supported from below??? Dow and grout??? Anyone with experience to share??? Thanks |
Re: Patching Penetrations In Concrete Roof Deck
How large are openings and will the exposed to view side be painted? I have had great results with 10K grout, doweled on larger penetrations.
We generally wipe the existing concrete down with SilPro C-21, Tapcon a form to the under side and pour. Larger penetration would obviously have to be formed and braced accordingly. A band of GreenStreak Hydrophilic waterstop around the perimeter of the joint is a good idea if water-proofing is required. Do not use the hydrophilic unless you have a minimum of 2" of cover above and below. I have used this method to patch concrete decks and core drill holes in public pool walls. If you use the 10K non-shrink grout we have patched holes up to 12" in diameter without doweling. This will result in a very strong and leak-proof patch. The ones we have done in pools hold back a 4' to 6' head of water. |
| roof valley | Fix-it | Carpentry | 3 | 11-12-2007 07:41 PM |
| Building a deck on a roof | eddieapoc | Decks & Fencing | 4 | 09-22-2007 12:13 AM |
| Roof repairs | PA woodbutcher | Roofing | 6 | 09-14-2007 11:20 AM |
| deck roof | haskl33 | Framing | 9 | 09-06-2007 01:00 AM |
| Deck roof | Brian | Decks & Fencing | 0 | 01-25-2007 12:47 PM |
