Oil Stain Rermoval From Concrete
Old 03-20-2009, 03:33 PM   #1
jfikentscher
Guest
jfikentscher's Avatar
Posts: n/a
The diesel car dripped all over the driveway this winter. Any suggestions for removing the stains?
Old 03-21-2009, 02:04 PM   #2
Concrete Firm
Guest
Concrete Firm's Avatar
Posts: n/a
Re: Oil Stain Rermoval From Concrete
If a common detergent and scrub brush will not work then try a powerful degreaser such as simple green, purple power, or mean green. If that will not get it up, then another solution may be what is known as a poultice, which is an absorptive material like kitty litter or sawdust saturated in a strong solvent like, Acetone, Xylene, Lacquer thinner, Or MEK. Once it is saturated, cover it in plastic and give it awhile to brake down the stain. Once it is broken down you should be able to wash it with a brush and detergent. Hope this helps.
The Following User Says Thank You to For This Useful Post:
Old 03-23-2009, 04:10 PM   #3
jfikentscher
Guest
Posts: n/a
Thanks for the response. I'll get some simple green tomorrow. My wife is really upset about the stain.
Old 03-23-2009, 05:40 PM   #4
mdshunk
Guest
mdshunk's Avatar
Posts: n/a
Cover it w/baking soda. Sucks it up pretty well. Repeat every day for a good while.
Old 03-23-2009, 06:11 PM   #5
AAA Gutter
Guest
AAA Gutter's Avatar
Posts: n/a
I just bought a bag of oil dry (the granular stuff that is kind of like kitty litter) at HD
I poured a pile of it on the oil stain and then ground it into the stain with my boot until it was powdered, the stain was gone! took about 15 minutes, and 2 beers
The stain was accumulated over 4 years from my daughters car.
Old 03-23-2009, 10:47 PM   #6
Chris Johnson
Guest
Chris Johnson's Avatar
Posts: n/a
If all else fails, 20 more gallons of diesel and finish the job
Old 03-23-2009, 11:31 PM   #7
WarnerConstInc.
Guest
WarnerConstInc.'s Avatar
Posts: n/a
Brake cleaner.
Old 04-01-2009, 01:14 AM   #8
Hoven
Guest
Hoven's Avatar
Posts: n/a
poultice powder
Staining concrete ryan.s Masonry 12 03-05-2009 03:54 PM
Concrete stain problem Forry Concrete & Paving 6 09-02-2008 09:10 PM
Concrete countertop acid stain problem AHS Concrete & Paving 12 05-09-2008 02:14 PM
Concrete paint or stain? cjc Painting & Finish Work 4 08-06-2007 10:12 PM
I want to do a concrete acid stain in our house- how hard/expensive is it to do? Melissa Masonry 19 02-08-2007 10:56 PM
