Moisture Barrier
Old 05-13-2007, 03:48 PM   #1
BKA's Avatar
Trade: Comercial Sales
Moisture Barrier
As a flooring guy we get lots of problems from moisture. Does anyone have a way to check if the moisture barrier is intact without major demo?
BKA is offline
Old 05-15-2007, 10:07 PM   #2
tgeb's Avatar
Re: Moisture Barrier
Just off hand I would say that if you have alot of moisture problems, what difference would it make if the vapor barrier is in place or not? You still have to remedy the problem, No?
But to answer the question I have no way of knowing if the poly is in place with out doing some demo, you could core drill. As small as 1" or 2" core should be enough to see if the poly is under the slab. I would not consider that "major" demolition.
www.gebcon.com
tgeb is online now
Old 05-16-2007, 12:41 AM   #3
BKA's Avatar
Well the point is if it is the moisture barrier it is not my fault. If the moisture barrier is intact then it might be my fault.
Purley a CYA issue. Not an operational issue. No problem to fix just I want to know whose fault (real liable) it is.
BKA is offline
Old 05-16-2007, 04:53 PM   #4
tgeb's Avatar
I understand.
I would say the small core drill would be the easiest way to verify the poly below slab. The problem is that just because it may be present where you take a sample, does not mean it is present everywhere or that it is installed correctly.
Good luck sorting it out.
www.gebcon.com
tgeb is online now
basement vapor barrier zmusashi General Discussion 9 06-08-2009 02:23 PM
Floor Barrier Hardibuilt General Discussion 0 04-04-2007 01:02 AM
Condo renovation - water proofing inside of vapor barrier??? LennyV-NHSNOLA Remodeling 2 03-27-2007 10:08 PM
Acceptable moisture content of unfinished hardwood Grainywood Flooring 2 09-24-2006 08:46 PM
Vapor barrier question Lone Wrencher Drywall 2 01-30-2006 10:48 PM
