Mix Designs
Old 06-02-2007, 09:44 PM   #1
stampcrete's Avatar
Trade: concrete contractor
Mix Designs
I was wondering what different mix designs are being used for stamped work. Do you guys use your own admixtures or do you order them with the load.? Maybe a stupid question but im curious what other guys do.
-Kirk
stampcrete is offline
Old 06-02-2007, 10:16 PM   #2
concretemasonry's Avatar
Trade: Masonry consultant
Re: Mix Designs
Aggregates and weather conditions vary around the country, so there can be no set answer for everywhere.
Since you are selling a quality, exposed, labor intensive product, material cost is not that important if you get what works and sells more jobs. Try to find out what has worked using the local materials in your weather conditions.
Contact the local ready-mix supplier and lean on him to give you the best mix without trying to buy cheap. He does not want bad jobs and someone else adding the wrong "spit" and getting into the middle of a quality situation he had no part in.
Once you have the mix specs, then it is up to your skill to build your reputation and long-term profits.
If you know your competition well, contact him since he does not want someone giving away work at a low price OR do poor quality work that affects his future. - I was around the CT masonry business for a while and it seemed to operate that way.
Dick
concretemasonry is online now
Old 06-03-2007, 04:33 PM   #3
POOLMANinCT's Avatar
Re: Mix Designs
concretemasonry.....
did your get the feeling the CT masonry biz is a "secret guild"......
stampcrete, I'm sure you know "joe peppers"
......Less with the jaw & More with the paw.....
POOLMANinCT is offline
Old 06-03-2007, 08:51 PM   #4
stampcrete's Avatar
Re: Mix Designs
" joe peppers" I never heard of him or them , fill me in. -Kirk
Old 06-03-2007, 09:14 PM   #5
Re: Mix Designs
POOLMANinCT -
At the time I was in CT, it was definetly a closed group. This was around 1990. It probably (hopefully) has changed since then.
I was to monthly meetings of the contractors where they have "closed" meetings prior to the general meeting. General indusrty subjects were later discussed openly.
I also have been to the lunch meetings in New Haven (the old walled restaurant) and to the "Society" house south of Hartford (you had to wear either patent lather shoes or a flannel shirt). In about 1989, I was requested by contractors to attend the funeral of a promenent political/construction figure. This may be close to the "secret guild" you referred to.
Some material suppliers were advised to include either one or two $50 bills in an envelope with the driver depending on where the delivery was to go (lower CT, NYC or LI). - Apparently for someone on the other end - I assume it was a union thing.
That was a few years ago, but it was a firmly entrenched structure at the time. - Not a model of good construction practices.
I know the business practices have been changed and the international acquisitions have provided a more professional direction to business. The suppliers currently operating have a wealth of technical support and experience that should be used to complete a successful stamped concrete job.
Dick
Old 04-28-2008, 11:44 PM   #6
deco-art's Avatar
Trade: Concrete work
Lightbulb
Re: Mix Designs
If you want a good stamp mix. Do some research and find out what you need. I use Scofield colors and they recomand no less than a 4000 psi, and no more than 10% color to concrete ratio. Some stamp guides also say to use 1/2'' stone instead of 3/4'' stone. I like to use a 4000 psi and a powerscreed to get a bit more cream to the surface.
deco-art is offline
toolbox/belt designs graemebillo Tools & Equipment 3 01-31-2007 12:15 PM
Timeless designs. K2 General Discussion 10 11-07-2006 01:45 AM
plans and designs Humble Abode Carpentry 5 05-27-2005 10:29 AM
Kitchen designs for customers Mike Finley Business 4 05-11-2004 09:44 PM
Contractor Web Designs web designs Construction 1 03-23-2004 04:52 PM
