Large Patio Question
I am forming a large patio that house a house on one side and concrete retaining walls on opposite sides of each other and then the fourth side is open to the yard. The size of the slab is 45' wide by 16' deep (with a 6" base of #57 gravel and a pour depth of 5"). My question is this...I plan on putting rebar into the house and both retaining walls to keep the pad from ever slipping, but should I use some type of expansion joint material against the other existing concrete? And how far apart should I put my control joints in a slab of this size?
Thanks!
Doug Brandt Class "A" Contractor Brandt Custom Homes Roanoke, VA |
Trade: general contractor
Re: Large Patio Question
A rule of thumb for cutting is 3 times the thickness in feet so 5'' would be every 15 '.As far as expansion joint, there is some debate, some say the slab never gets bigger than it was when you poured it, personally I think if that was the case why do they have trouble with freeways buckling in the heat! I always use expansion joint when the slab is trapped between two stationary points.Its a cheap precaution and also gives you something to screed off of on the sides.
OK...sounds good...but should I still tie rebar from the pad into the existing house structure AND the retaining walls? I plan on using 4,000 mix with fiber & air added, if that matters.
i wouldnt tie to the house or retaining walls, i feel there is no need.
question #2 id oil & pull my forms, then foam backer-rod cap orr backer rod w/ flex expansion joint mastic. ray |
Hard to answer without seeing the grade but unless you have fresh backfill or have a chance of settling for some reason you probably wouldn't have to pin.
| Question about bidding vinyl wallcovering | kanadaeh | Painting & Finish Work | 9 | 02-19-2009 05:29 PM |
| Common Patio Door Problems | adriand | Remodeling | 1 | 01-14-2007 01:27 AM |
| Patio Expansion | andy998 | Masonry | 6 | 08-20-2006 06:32 PM |
