ICF Concrete?
Old 07-18-2010, 05:33 PM   #1
sbcontracting's Avatar
Trade: General Contracting
Rewards Points: 562
ICF Concrete?
Is concrete for a below-grade ICF foundation any different than the concrete I'd get from a regular poured wall?
I have a quote from an ICF provider here in Ottawa which includes concrete. Thought it was a little peculiar, and probably just a way to increase margins - but I'm guessing I could order the appropriate mix from local cement co myself...
Thanks in advance! Mike
sbcontracting is offline
Old 07-18-2010, 05:36 PM   #2
Joasis's Avatar
Rewards Points: 1,396
Re: ICF Concrete?
Concrete mixes are designed for a specific application, and ICF's typically have a design mix that lends to easy consolidation, and strength, plus small aggregate size. It will have a plasticizer as well....so I guess your concrete guy will give you an answer about what they can sell you and the design mix.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
The Following 2 Users Say Thank You to Joasis For This Useful Post:
eliteconcrete (04-28-2011), sbcontracting (07-18-2010)
Old 07-18-2010, 05:49 PM   #3
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,912
Re: ICF Concrete?
Because it is ICF, there could be some pumping and truck time charges to bring the concrete up reasonably equally all around in case the guy setting the forms was sloppy when it comes to bracing and stability.
Dick
concretemasonry is online now
The Following 2 Users Say Thank You to concretemasonry For This Useful Post:
Old 07-18-2010, 07:14 PM   #4
Rewards Points: 562
Re: ICF Concrete?
Thanks. The guy doing the forming/bracing would be me. I was hoping to do it without a pump as I was planning to be able to have a truck get to about all sides. But with a 6" wall that might prove challenging. I may insist on the pump truck.
Old 07-18-2010, 11:32 PM   #5
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 190
Re: ICF Concrete?
I have only seen 3 foot 'lifts' allowed on ICF pours.
Your 6 foot walls will needs 2 rounds of pouring or pumping.
Vibration required.
jlhaslip is offline
Old 07-19-2010, 12:31 AM   #6
pumpjockey's Avatar
Trade: concrete
Re: ICF Concrete?
Mixers will generally not get very close to an excavation anymore. Pumps are too easy to come by and that is what they do best.
For what they charge, they are a great value, they save a lot of time and effort in placing the concrete where it needs to be.
pumpjockey is offline
The Following User Says Thank You to pumpjockey For This Useful Post:
Old 07-20-2010, 07:45 PM   #7
Rewards Points: 562
Re: ICF Concrete?
Thanks folks.
The solution is that they aren't going with any foundation period and building a slab-on-grade garage (single storey) which is in line with building codes up here.
I'm disappointed as I was keen to do ICF not having done it before. I was surprised to see that cost-wise it seems to be pretty comparable to old-fashioned formed concrete walls... Or at least the way I was pricing it, anyway!
Old 11-11-2010, 12:06 PM   #8
jdorpaudi's Avatar
Trade: carpenter
Rewards Points: 97
Re: ICF Concrete?
we were pouring a 12 ft high icf wall (first high wall pour with icf) and we were doing 4 ft lifts for the first half. the second half we did 6ft lifts. no problems either way. i asked the pump operator how high he has poured icf, he said 12 ft. so then i asked if we could have done it, and he said that the bracing we had was done very well and he had no doubt we could have done it in one lift.
jdorpaudi is offline
Old 11-11-2010, 05:56 PM   #9
MSLiechty's Avatar
Trade: Bender Of Nails
Rewards Points: 428
Re: ICF Concrete?
I wish i had some pictures but two years ago we worked on a 5 plex theater project. everywall was ICF. Out here no one does ICF's and i think they went through 3 subs on that job. nothing like a blowout 6' off teh deck when your pouring 28' tall walls.
ML
MSLiechty is offline
Old 11-18-2010, 07:03 PM   #10
eliteconcrete's Avatar
Trade: concrete
Re: ICF Concrete?
ICF is a good option for some industries, but you need to be familiar with the intricacies of the properties of this type of concrete.
Ask us your toughest concrete questions
Elite Concrete Restoration
Follow me on twitter @EliteConcrete
eliteconcrete is offline
Old 04-13-2011, 08:38 PM   #11
INHOFF systems's Avatar
Trade: Insulated Concrete Forms & GC
Re: ICF Concrete?
Well, this being my first post on this site, I hope that I can answer some of your ICF questions.
We are a Canadian Manufacturer & Supplier of a Vertical ICF system.
We personally have poured walls as high as 17ft in a monopour (they have gone significantly higher in the USA), as well as suspended slabs with 13ft high walls in one shot. Several lifts mind you (generally 4-6ft).
We have also done 3 1/2" concrete cavity (nom. 4") in 10ft heights without problems. For these thinner walls, we do recommend a plasticizer, especially when it's hot. For all other walls, a 4 1/2" - 5" is perfect. No need to go with a "soupy mix". We do prefer to use a pumper truck, mainly for accessibility and ease of doing the job. It's generally not a requirement.
Matt
INHOFF systems is offline
The Following User Says Thank You to INHOFF systems For This Useful Post:
Old 04-13-2011, 08:48 PM   #12
Trade: concrete
Re: ICF Concrete?
@mike you can get the concrete yourself, provided you use a plasticizer, however if you are at all nervous about setting the mix yourself it would be a good idea to get your product from the concrete contractor.
Old 03-19-2012, 06:07 PM   #13
CritterCon's Avatar
Trade: Roofing
Re: ICF Concrete?
So when you pour each lift, how long in between do you wait? Thanks...
CritterCon is offline
Old 03-19-2012, 06:51 PM   #14
Joasis's Avatar
Re: ICF Concrete?
Plan on trying it yourself?
The reason for multiple "lifts" is to allow for consolidation, and relieve the stress on the forms. The concrete will take an initial "set" in the time it takes to go around 200 feet of walls. Reduces pressure on the forms, lessons the chance of blowouts, and better control of plumbing the wall if there is a problem.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
My Facebook Page
Joasis is offline
Old 03-19-2012, 08:15 PM   #15
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
Re: ICF Concrete?
A typical form is rated for, or tested for 800 psi +/-, a 6" ICF form with 4' of concrete is about 600 psi on the bottom, once you surpass that pressure increases immensely.
Check you local safety code as well, ACI 318 used to talk about 4' lifts per hour and when I was in California, CalOSHA mandated a maximum of 12' (3 lifts) in one day!
Chris
Chris Johnson is offline
Old 03-19-2012, 10:17 PM   #16
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
Re: ICF Concrete?
Im not sure if it has been said above. but ICF concrete is really no different (as far as i know) then regular concrete. The main difference may be the slump, to ease consolidation.
IF anything the ICF concrete may be stronger because ICF is an "engineered" product.
I think thats what Chris ^ told me
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Old 03-19-2012, 10:39 PM   #17
I'm a Mac
Re: ICF Concrete?
I use regular mix design concrete, most ICF mixes contain plasticizers and pea gravel to help them flow. Once you know what you are doing, save money and use regular mix. The main key is consolidation
Chris
Old 03-20-2012, 10:30 PM   #18
CritterCon's Avatar
Trade: Roofing
Re: ICF Concrete?
Thanks! I'm building myself a house. I've poured walls with forms, but not ICF. Looking around at different brands to see what I like.
Concrete Company delivered junk concrete. How best to pursue? marcomjl Concrete & Paving 47 06-03-2014 10:17 PM
Concrete with Fly Ash vs. Concrete without? cdkyle Concrete & Paving 19 07-28-2010 09:57 PM
Tire line in concrete after finishing. aydin_eng Flooring 34 03-09-2010 09:03 PM
4x4 posts in concrete vs. saddles Strongarm Decks & Fencing 20 08-31-2009 09:41 PM
