Hydronic Heated Driveway
Old 09-06-2009, 04:40 AM   #1
Griffino's Avatar
Trade: General Contracting
My client needed heated 210' x 25' road between 4 triplexes. It's a new site so hydronic was an easy decision, but the road type was not. All the contractors we talked to said concrete, we knew it was going to set us back more then asphalt but every plumber and dirt/road professional more then suggested concrete for a number of reasons. I wanted it for aesthetics, the plumber wanted it to keep heavy asphalt machines from driving over the hydronic tubing, the dirt professional didn't want to put another substrate down such as sand or a slurry to cover the tubing before asphalt to protect the tubing from above said risk, not to mention the added cost and time. Also, no matter what substrate we used under the ashpalt, the thermal transfer would be nill, especially sand. For these reasons and more, we went with concrete.
Well, the dust settled and my client is pissed! He said people do the asphalt "on the east coast" all the time, he thinks all the above worries are crap and is looking for a head to lob off, it may be mine. I think he's pissed about something entirely different and is projecting....I also think he missinformed or full of . Am I wrong? Shall I mention we got it done in time and under budget?
Griffino is offline
Old 09-06-2009, 05:02 AM   #2
genecarp's Avatar
Re: Hydronic Heated Driveway
Radiant under ashphalt is commonly done in the northeast (DUE DILIGENCE)
http://www.drivewayheating.com/site/...t-applications
genecarp is offline
Old 09-06-2009, 05:13 AM   #3
Griffino's Avatar
I looked at that specific website and others concerning electric options. One problem: 30w per foot x 4600ft = 138000 watts / 120vac = 1150amps = 4x0000(.46) cables to power the load.....I think you see what I'm getting at.
Also, the average temp and snowfall for this area is 35f/121inch. It would be prohibitively expensive to heat with electric.
Griffino is offline
Old 09-07-2009, 01:03 PM   #4
Griffino's Avatar
bump
Griffino is offline
Old 01-06-2010, 06:37 PM   #5
Youngster
Cache's Avatar
Trade: Builder / Consultant / Designer
I've got the same issue right now. HO wants heated drive, but wants asphalt drive with stamped concrete borders. Electric is a no go. Must be hydronic. Read an article somewhere that prescribed dense foam underneath asphalt. Didn't know if that was kosher. What say all you pavers?
Cache is offline
Old 01-07-2010, 11:56 PM   #6
TERM101's Avatar
Trade: General Construction
I see it done around here quite often, especially in the richer neighborhoods. The dense foam usually wouldnt be a problem depending on the density of the foam they are prescribing. Asphalt has excellent tensile strength where as concrete does not. You would be surprised how much asphalt "gives" when heavy loads are driven over it.
TERM101 is offline
Old 01-08-2010, 11:20 AM   #7
Youngster
Cache's Avatar
Would you be willing to ask around and see what density people are using around there? I've also heard of simply using crushed volcanic rock as an insulator in this case.
Cache is offline
Old 01-08-2010, 11:48 PM   #8
TERM101's Avatar
Actually you are correct. Perlite volcanic rock will provide just as good of insulation and most foams. I think it actually will do a better job. Ofcourse this is just an opinion. If it were me I would go with the rock.
TERM101 is offline
Old 01-14-2010, 01:28 PM   #9
Concrete Mike
CONCRETE MIKE's Avatar
Trade: concrete
What? If that is true then why is airport runways made with concrete and not asphalt? Well the answer to that question is that concrete is better, harder, and lasts longer. Do it the correct way CONCRETE!!
CONCRETE MIKE is offline
Old 02-07-2010, 02:52 PM   #10
Griffino's Avatar
Concrete is the best way to go in terms of longevity and finished product, asphalt is a just used to save money. I believe it can be done by insulating the substrate, laying tubing, then adding a layer of sand or RAP to distribute the weight of the asphalt machine around the tubing.
Griffino is offline
Old 02-07-2010, 02:56 PM   #11
Griffino's Avatar
So it's all said and done and the feedback is massive, many say, "this drive will sell these units!" The owner said it was a good decision after all, and the asphalt guy who said I was off my rocker, actually apologized and said he was wrong about me. Good times!
Griffino is offline
Old 02-10-2010, 09:02 AM   #12
TERM101's Avatar
Good job, congrats :-)
TERM101 is offline
Old 02-10-2010, 09:29 AM   #13
Designer/Contractor
Rio's Avatar
It's great everything worked out but I'm surprised that the plans didn't call out for what was going to be used. That would have removed any chance of getting in a big fight over what was supposed to be done......
Rio is offline
Old 02-10-2010, 09:32 AM   #14
Anti-wingnut's Avatar
What an extravagant waste
Anti-wingnut is offline
Old 02-10-2010, 10:36 AM   #15
rustyjames's Avatar
Until the heating bills start rolling in
rustyjames is offline
Old 02-11-2010, 07:59 PM   #16
Griffino's Avatar
Amen to that, but the clients don't want to plow or shovel their walks or drives. This is a great solution for them. I guess if they sell......
However the road bill has not come in yet, the driveways are on the unit's individual billing and it's far less expensive then expected.
Griffino is offline
Old 02-11-2010, 08:31 PM   #17
CanCritter's Avatar
Trade: bricklayer/stonemason
subscribed
CanCritter is offline
driveway black top issue eekie34 Concrete & Paving 8 05-29-2009 03:30 PM
Asphalt driveway rayh78 General Discussion 1 05-22-2009 07:01 AM
Pouring new driveway on top of old driveway Brock Concrete & Paving 8 12-01-2008 04:39 PM
bonding agent for stone driveway rocknhammer Specialty Trades Picture Post 5 09-28-2008 07:25 PM
Someone used my driveway without permission Sportbilly General Discussion 40 03-02-2008 09:56 PM
