Trade: concrete
Gringing/polishing Advise With Photos1
HI
here is parking area photos attached, concrete isn't smooth, not power trawled, uneven and in some places bumpy it's only poured and that's it I need to make this site clean and look good I was advised scarifier, grinder and polisher but my budget isn't so big to buy all of them Please advise how can i fulfill job Thanks I'll attach more photos |
Re: Gringing/polishing Advise With Photos1
Rent the equipment or think about an overlay
Thom
Looks to me like an overlay might be your best bet. Before you do anything check the thickness and quality of the existing materials. The work looks bad enough that it makes sense to question materials quality. There is no point in doing a quality overlay on top of something that will fail soon.
Looks way to f ---d up to grind IMO. Assuming the concrete is thick enough and of proper quality, i would be considering an overlay... G
Trade: concrete
please advise equipment i need to rent?
Trade: Commerical Construction
wheres the expasion joints?
Trade: concrete
you mean mortar overlay ? ( i'm from republic Of georgia and tht's whay i'm asking strange questions
)just imagine that it's your site, your budget is limited but you need to make it as a normal parking area what you gonna do ?? what are any other options rather then grinding ?? what is the most reasonable way ?? |
Hoven
Trade: Decorative concrete / Comercial /residential flatwork
Looks like they poured wet and piddled it with 2x4. Looking closer at the photos around the edges there is alot of crete just sticking up. If I was going to fix this I would probably cap that mess if posible. By the time you profile, , grind edges, and clean the area it may just be all for nothing because the floor itself looks all over the place. Do the pitches work now?
You may have to remove some of the area near the exterior door to get a good thickness. Use wire reinforcement, fiber and readymix concrete with a polymer you can add into the truck before you pour. Again I cant see the whole area to be definitive. An overlay may work on the cosmetics, but it will just mimic the pitches you have now. |
Trade: concrete
what about polymer modified overlay ? wil it works ? does need any floor preparation ?
Hoven
The polymer is what gives the material it bonding properties. Overlays tend to fail at thicknesses over and inch or so. I haven't found one yet that can make up say 2 inches and feather to almost zero . If anyone does know of one let me in on that secret please. They are designed to work thin. So areas that are real low may require additional applications to make this floor appear some what flat. I still think a cap is the way to go if possible. Get a transit take some readings and see what your working with first.
Trade: concrete
what about this ?? will it works ?
Please advise |
Trade: Specialty Contracting
That milling head will leave about the roughest floor possible. They are used for removing a large amount of material in one pass. Think of a road resurfacing project where the entire top layer of road is removed. Very rough afterwards.
Trade: Perfessional Contracter
I would jack hammer it out and start over. Concrete grinding is no fun and you have A LOT to do. Don't throw good money after bad.
Hoven
Like i said before cap it and jack out what you need to near the exterior doors.
solar guy
Trade: solar contracting
one word Ardex
I hope you didn't pour this Last edited by naptown CR; 05-19-2009 at 11:02 PM. |
Matt
WOW! I mean...WOW!
#18 |
solar guy
Re: Gringing/polishing Advise With Photos1 |
#19 |
Trade: General Construction
How in the world did that happen? Thats not a job for a first timer! Did the company not own a mag screed or even a bullfloat? No one even attempted to finish that! Tear out and repour!
#20 |
Trade: FORMWORK & FLATWORK CONCRETE CONTRACTORS
Damn , what a mess !
| Advise And/Or Floor Sanding Contractor Geneva, IL Area Needed | Ed the Roofer | Flooring | 5 | 03-20-2009 08:12 PM |
| Exterior Slate Tile Balconies - Need some advise | NAV | Ceramic & Stone Tile | 5 | 01-06-2009 06:36 PM |
| Tiled shower leaks...Could use any advise at all... | Jay22 | Ceramic & Stone Tile | 17 | 12-10-2008 07:15 PM |
| New painter in need of some advise | Cramerica80 | Painting & Finish Work | 14 | 10-14-2006 09:52 AM |
