Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Concrete & Paving
Old 08-29-2008, 10:46 PM   #1
Trade: General and Electrical Contracting
Question exterior Concrete side walk enforcement
Hello everyone,
My question is if there is a code that requires use of minimum enforcement
material like wire mash for exterior concrete side walk subject to vehicle traffic other than public side walks.
maghazadeh is offline   Reply With Quote
Old 08-30-2008, 12:59 AM   #2
Bunny by Malco - NY
Chris Johnson's Avatar
Trade: ICF Construction
That falls under the 'ask the engineer' catagory
However if it is on public land, the city generally does not want rebar in the concrete so as when they have to break it out down the road it comes out much easier!! I know it sounds silly, but that is their theory in the municipalities I have worked in.
Chris
Chris Johnson is offline   Reply With Quote
Old 08-30-2008, 04:53 AM   #3
Chris thank you for your reply, however my question was other than public work or public ares, is there a code(UBC) that requires to reinforce the concrete in some means? if there is and anyone knows, please reply and tell me where to look for it with a code or article #.
Thank you all
Old 08-30-2008, 04:59 AM   #4
Correction on last reply, assuming there isn't an engineer of the record to ask. I am seeking for a code that requires reinforcement.
Thanks again
Old 08-30-2008, 07:58 PM   #5
Hoven
Trade: Decorative concrete / Comercial /residential flatwork
Here in RI there isn't any. But its cheap to add and you only get one chance to do it right ...spend the money
Hoven is offline   Reply With Quote
Side Work specwood Business 81 05-12-2009 06:19 AM
About to walk away from this one J-Peffer Roofing 12 06-17-2008 01:00 PM
Side walk and patio bases doubleaction Concrete & Paving 3 06-05-2007 08:12 PM
Green Side Up Double-A Off Topic (Non Trade) 5 11-05-2006 08:39 AM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 08:48 PM
