Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Concrete & Paving
Old 09-18-2009, 02:40 PM   #21
DavidC
DavidC's Avatar
http://www.concreteexchange.com/ should get you started. I read his book and started looking for a guinea pig customer. Have fun with it.
Good Luck
www.CookContractingLLC.com
"If the front door is locked, check all the windows and if that fails cut a hole in the roof." BenHur
DavidC is offline   Reply With Quote
Old 09-21-2009, 02:40 PM   #22
jcalvin's Avatar
thanks for the link. it might take me a while to ever take the pluge, if i do. i do plan on trying something for my personal home. do most of you pour in place or pour at your shop and move it in? is it possible to get a decent finish w/o a concrete vibrator using a palm sander and car buffer for finishing? if not, what do you use for finishing?
Cal
You hired WHO
jcalvin is offline   Reply With Quote
Old 09-21-2009, 05:05 PM   #23
DavidC
DavidC's Avatar
Diamond grit grinding discs and a wet grinder to finish the surface followed by a sealer to polish and protect it. I tried a palm sander (didn't think it was working very well) and a blade less sawzall (which didn't work much better). The end result was some poc marks in the surface. Made a small batch of portland + dye + bonding agent and filled most of them easy enough.
Grinding started at 50 grit and took 5 steps up to 1500 grit. On our project I used paste wax and a buffer for the seal and polish. There are much better products out there. Wax and heat, not so good for example.
Good Luck
Old 09-23-2009, 12:15 AM   #24
Trade: Drywall
great thread!
I just finished my first countertop (a vanity top approx. 5'x2' with a couple of jogs in it). I built the forms out of melamine, and used foam in the bottom of the form for a recess for the cabinet. I used quikrete countertop mix which i liked alot, and had pretty good luck with a palm sander for vibrating. My one regrettable mistake was mixing the material with a shovel instead of a mixer. I ended up with one small dime-size chunk of dry pack that ended up flaking out. I repaired it by mixing portland, color, and bonding agent (which worked fine).
One bit of advice i would add for patching/filling pits/etc. though, is make sure you dont spread the patching material over to much of the countertop. On my project it left a really light stain that soaked in a bit, and had to be ground out later.
......might try a coat of penetrating sealer before patching next time.
...anyone try that?
Bazooka Joe is offline   Reply With Quote
Custom Concrete Countertop Mixes duburban Concrete & Paving 6 06-09-2009 05:39 PM
Does anyone have a estimate form with a charge involved thegreek File Swap 11 06-07-2009 02:24 PM
In depth construction schedule form?? kdub1777 File Swap 9 02-17-2009 05:02 PM
What has been the most productive form of advertising for you? SmithBuilt Marketing & Sales 40 02-03-2009 11:13 AM
how to make a quick concrete countertop for vanity domanicapital General Discussion 2 04-09-2006 05:19 PM
