Goldie
Trade: general contractor
Control Joints In Concrete Steps
I have 10' wide concrete steps. There are 6 steps and they are 4'-6" long. Should I put a control joint down the middle or will that cause more non-controlled cracking.
the hurrier i go, the behinder i get
Hoven
Trade: Decorative concrete / Comercial /residential flatwork
Re: Control Joints In Concrete Steps
I wouldn't put a control joint there. A control joint is going to make it weaker at that point and probably cause a crack over time. I would however use # 4 rebar. I usually drill holes in the foundation and cut pieces about a foot and a half of 5/8'' rebar and pound them into the holes you drill. The #4 bar I usually put parallel with the riser @ approx 3 in from the face of the riser and 2 1/2 inches or so down into the surface to beef up that edge. With your 10' span I might just use 5/8 all around and maybe 2 pieces on the tred area equidistance apart. There is always time to do it right the second time. Steel is relativley cheap for this size project.
I would never tie steps to the foundation
unless they are completely supported by a foundation below frost! Never. As to the rest of the question I don't understand. Are they 10' wide and 4'-6" deep treads? Or 4'-6" wide and 5 treads total 10' deep? Or......?
Hoven
Sorry, I was assuming there would be a footing for a step this size. And yes I would pin to foundation to avoid tipping overtime. The step and the footing are going to be extemely heavy and for the sake of a couple of pins why take the chance of looking like a fool down the road.
| Concrete Slab control joint. | K2 | Construction | 11 | 05-14-2008 03:53 PM |
| wood over concrete steps | Patrick | Decks & Fencing | 3 | 04-09-2008 11:51 PM |
| Tiling over Concrete Expansion Joints | Clueless | Ceramic & Stone Tile | 16 | 11-25-2007 11:48 PM |
| resurface concrete steps | haskl33 | Masonry | 0 | 10-04-2006 10:13 PM |
| Candle Wax on Concrete steps | balanceact | Masonry | 9 | 08-20-2006 04:08 PM |
