Trade: stonemasonary
Concrete White And Dark Patches
Hi thanks for taking the time to read this i am a stone mason by trade i specalize in granite and marble i made benchtop and vanities and also headstones. But now for the last 2 years have been installing and reparing headstones or if you are in the usa gravestones. So i have had to teach myself concrete and plastering which i think looks good. I work for a boss and there is one other person there. The question is i do a lot of concreting and i have notice that the concrete that i have poured after a month or so is white in some areas and dark in others so it is quite patchy is this because of not enough cement or is taking longer to dry because it is quite deep about 10 inches. If anyone knows that would be great also the concrete was mixed in a mixer thanks for your time.
Re: Concrete White And Dark Patches
Hi i have uploaded a photo of the concrete to my album if you want to see what i mean thanks.
WHAT color portland are you using?
how did you finish the surface? by hand, or some type of form?
Hi it was grey portland cement and finished with a steel float.
Stone, what is your climate (during the pour?) is the effect on the verticle surfaces, or only the horizontal? Did you cover the pour after finishing? Welcome to CT, what country are you in? G
Hi the walls were plastered so all i can say is the top panel the weather was mild and it wasnt covered i went back the next day and watered it with the hose. Thanks for the wellcome.
Location is the North Island of New Zealand.
Is there any difference in the texture from the dark to the light? when you hosed it down, is it possible you removed some of the cream from various spots, exposing more aggregate and causing a color change?
Hi the surface is the same and no it hadnt washed of the top coat its just light in some areas and dark in other as in the photo thanks.
PRO
Trade: CGC Concrete
I have the samething happen to my concrete. None of mine is hand mixed all ordered out of a truck. It looks normal to me. Concrete never stops curing. Majority of the curing process takes place in the first 28 days, this is why they crush the final cylinder in a psi test on the 28th day. This being said I think the finish looks good it just needs more time to bleachout to the nice light grey you are used to. I have had slabs with cure and seal on them take 4+ months to bleach out.
Thanks Blackhammer for the info it is amazing the art and science behind concrete it gets taken for granted.
Trade: We perform landscape design and construction
I had the same with transit mix on a driveway, we did two driveways side by side. Called the mix company and they said the sun will bleach it out?
It took almost two years and visits to court to finally get paid. I now have a new clause in my contract about color and blotches |
Hi steve did they every find the cause of the blotches and did they go away and if so how long did it take thanks
#15 | |
Small peanuts
Re: Concrete White And Dark PatchesQuote:
Love the guaranteed to crack clause....only two types of concrete; cracked and going to crack.
#17 | |
Small peanuts
#18 |
Trade: media blasting
I used to run a ready mix plant I would only guarentee 3 things. It will come in a big truck it will get hard and it will crack.
#19 |
Trade: General Construction
Ive notice that sometimes inconsistent floating/troweling in some spots versus other spots will cause different water concentrations in certain spots and cause these white splotches. Also covering concrete with anything will sometimes trap the bleed water and allow it to just set under whatever is covering it, this sometimes causes light areas.
