Concrete Stamping
Old 01-05-2009, 07:29 AM   #41
joasis's Avatar
Re: Concrete Stamping
Originally Posted by doubleaction View Post
I use Liquid release mixed with powder release for color. I mix 1 gallon of liquid to 1 cup of powder to get the color. So far i haven't had any problems. And this way i can go back and spray more release on to areas to get more color. Here are a few pics of my last few jobs.
Color hardener mixed with something like the "bubblegum" release? Will this work well on a good range of color? If you have to tint it darker, I would guess you use acid a day later?
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 01-05-2009, 11:55 AM   #42
It is what it is
doubleaction's Avatar
Trade: Roofing, Remodeling, Concrete
No i Use the powder colored release with yes "cherry" release (same thing as bubblegum just smells different) then spray my stamps with it and the concrete. Then i can i back and look when its all stamped and add more color where i need to.
Patriot Broadcasting Network
doubleaction is offline
Old 01-05-2009, 12:03 PM   #43
It is what it is
Originally Posted by Shark49 View Post
I am a general contractor up in the mountains of NC and have a potential client who wants to tear up the existing ceramic tiles off of his front and rear concrete decks and then do a stamped overlay. I could probably get away with adding an inch max.
I have never done this before as most work I have done is new "bare" sog concrete. I have no issue hiring a sub of course but my main question is what is the best course of action for this? I realize the surface would have to be cleaned/scarified and prepared to take on a new layer of whatever is chosen. Or maybe just clean it it really good and do a stain? Or would it be easier/cheaper to just demo the concrete and start anew? Do I try and steer him away and go back to a stone surface? Very curious!
I would need something that will handle the cold winters and hot summers we see up here.
Can anyone point me in the right direction?
Thanks,
Nate
If it was my job I would remove the tiles and as much of the "loose' Thin-set as possible. If the concrete is still in good shape and you get the scaly or loose thin-set off then you can overlay it. I personally use flex-c-ment products because there is a guy 15 miles away that carries the stuff. I have been very happy with the results with there products. I am sure there are other equally good products out there. With flex-c-ment you "paint on a primer then apply you overlay on top of that. You can color and stamp just as you would with standard concrete. Im not pushing the product at all its just what i use and it works for me. Most of the decorative concrete supply companies are now carrying there own line of overlays, so you shouldn't have an issue with getting anything like that. good luck to you.
Old 01-05-2009, 12:09 PM   #44
It is what it is
Here joasis,
Here are a few better pictures of jobs where my method of colored release was used.
Old 01-05-2009, 01:59 PM   #45
joasis's Avatar
All I can say is "Impressive"!
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline
Old 01-05-2009, 03:58 PM   #46
It is what it is
Thank you
Old 01-05-2009, 04:05 PM   #47
gallerytungsten's Avatar
Trade: Design
Check out the book "Concrete in the home" by Cheng. He has a section on stamping, as well as lots of other interesting concrete fabrication and usage ideas. (He also has another book on concrete countertops that's also great.)
gallerytungsten is offline
Old 02-22-2009, 08:25 AM   #48
Trowel Monkey
Shaughnn's Avatar
Trade: Tile & Stone Contractor
Hi ARCS,
I just worked on a project with perhaps the best stamp job I've ever seen. This contractor and his guys took great care and the results are spectacular. They used Brickform temples and stain and a micro-fiber enhanced concrete.
Here are some shots of the backyard. Since I was taking these for the tile work (my work) the concrete isn't really featured in the shots. I've included three images hoping that you can get an idea of the depth and detail in the stamping. This backyard was poured in three separate phases to get clear color distinction.
Cheers,
Shaughnn
Concrete stamping-octagon-tile-004.jpg   Concrete stamping-octagon-tile-006.jpg   Concrete stamping-octagon-tile-011.jpg
Shaughnn
Capua Custom Tile & Stone
Card-carrying Schluter Systems installer
Certified Wedi Corp. installer
Shaughnn is offline
Old 02-25-2009, 06:29 PM   #49
shill's Avatar
Trade: concrete
Sharky, Here in New York We use what is called "Stampcrete Mirage" system. It goes on at only 3/8 of an inch and it's got a rating of 6000psi.
I've used it on alot of occasions and haven't had any major problems. It is expensive and you have to work fast with it as it sets up fast but I do highly recommend this product. I'd be willing to come down to help out if it were feasable and profitable.
Good luck.
shill is offline
Old 03-22-2009, 09:41 PM   #50
Hoven
Hoven's Avatar
Trade: Decorative concrete / Comercial /residential flatwork
You can lose your ass in a hurry with stamp work, materials are expensive. Many forces are always against you like hot weather, areas of the pour that are in the sun and some in the shade, hot loads, sealer problems, picky customers and rightfully so, they are paying top dollar for the work. If you want to try it, first try a seamless texture its the easiest. Once you move to a pattern with grout lines, now your into fixing imperfections which equals time and time is scarce on these types of jobs. I use Proline and Brickform stamps. If the stamps don't fit together exactly now your fixing it after you stamp it. Also Listen to Dick he is right on. No one ever talks about the 100 good jobs you have done...
Hoven is offline
The Following User Says Thank You to Hoven For This Useful Post:
jomama (03-23-2009)
Old 05-25-2009, 10:16 AM   #51
L-ENTERPRISES's Avatar
Trade: FORMWORK & FLATWORK CONCRETE CONTRACTORS
We use the Rock & Roller set up to stamp larger areas in a hurry ...... temp , slump & the factory release is the most important parts of getting this to work . We have done alot of golf course work with very good success . We can pour straight work at 100 cuyds per day with 6 guys and staged delivery .
L-ENTERPRISES is offline
Old 08-08-2009, 01:38 PM   #52
MZ-HANDYMAN's Avatar
Trade: Custom Home Remodeling 30+ yrs
Originally Posted by Same Old View Post
If you want top quality training go to The Stamp Store in Oklahoma City. The course is a couple days and is very hands on. He has a pretty neat checkerboard parking lot from all the pours done in the class.
Here are pics of the 2 sided parking lot.
MZ-HANDYMAN is offline
Old 08-08-2009, 01:58 PM   #53
Missed one from overhead.
Can't really see the details but pretty neat to look at.
Fiber Optics in concrete countertops 6stringmason Concrete & Paving 17 03-16-2011 05:49 PM
Staining concrete ryan.s Masonry 12 03-05-2009 03:54 PM
structural concrete... mdshunk Masonry 3 03-05-2009 03:42 PM
Concrete home denick Concrete & Paving 5 03-06-2007 04:32 PM
Hollow steel lally or concrete filled? kusa24 Construction 4 04-23-2006 08:49 AM
