Trade: Concrete
Concrete Sealer, Bad Mixture
I recently re-sealed a job and had a bad result. The job is a stamp job that was sealed with J-25 and I followed directions from a salesman (bad idea) and mopped the concrete with xylene which mad it look great. I then applied a product call glaze n seal, which is a laquer product that I have used many times and had no problem. However this was the first time I applied it over a different product, and it looked great at first, but very soon began to turn white and is continually getting worse. Does anyone know any techniques and or products that will help me perminantly fix my problem. I understand that it will require maintenance and would love advice on products for that as well.
Re: Concrete Sealer, Bad Mixture
you must chemically strip the sealer, no quick fix.
Trade: Epoxy Flooring & Concrete Overlays
Next time use a real sealer
contractor
Trade: power washing - new construction and restoration cleaning
Did you thoroughly remove the xylene from the surface before you applied the new sealer.
You always want to make sure that sealers are compatable with one another before double coating, otherwise you will need to completely strip the existing sealant off. It's never a bad idea to strip the masonry sealant off anyhow, especially since you already used xylene, why not finish the job and pressure wash it off completely. Using a solvent on sealed masonary surfaces will cause blushing as it dissolves the seal, or if the sealant is not breathable or doesn't adhere properly you may have blushing and discoloration, as well as some peeling up with a little time. What type of sealant was used? Siloxane based, Silane based, Silicate based, and so on and so on? Water or Solvent? How long of a dwell time did you apply the xylene? Laquer? I wouldn't use a laquer on concrete. Do you mean an acrylic polymer? We recomend using only breathable sealants that have been lab tested and field proven, otherwise you may be asking for trouble down the road. ProSoCo makes real good masonry sealants. www.prosoco.com Hydrozo from BASF also makes some good ones. Tech. Support: 1-800-243-6739 Gutter Clean & Power Wash Hickory NC Last edited by tom connelly; 08-29-2008 at 11:58 AM. |
Trade: Residential Stamped Concrete
I had the same thing happen at a job last fall. It was stamped concrete and I applied stampsheen sealer at around six in the evening on a fairly warm september day. The next afternoon I came to the job site and couldn't believe my eyes! The slab had turned white all over it. It almost looked like a layer of icing on a cake.
I ended up using a product called Resolve. It contains xylene and is pretty strong smelling stuff. It softens the sealer and drives it into the concrete so a new layer of sealer can be applied. I applied it with a pump sprayer, you just wait until it evaporates. Then there was a white crusty layer of dried sealer left after it was done evaporating. I preasure washed that off and reapplied a second coat of sealer. Worked well for me. The second application of sealer turned out good. I still don't really know what made the sealer turn white though. Over applicating?? Froze over night?? Don't know? |
#6 | |
Trade: Concrete Construction
Re: Concrete Sealer, Bad MixtureQuote:
A good stripper is Orange Peel, works great for removing Membrane sealers. As far as mopping Xylene on the surface, that is a not a good strategy, Xylene should only be mixed IN the sealer.
The Concrete Firm Offering Fine Concrete Services
Trade: decorative concrete
Seen it a thousand times; usually it's just moisture trapped. Give it a few hot sunny days and it usually goes away.
Concrete Decor magazine this month has a good article on sealers. |
#8 | |
Trade: masonry
Kamps Masonry & Concrete Countertop Design Green Bay, WI 920-680-3195 Visit our website @ http://www.concretecountertopsdesign.com/ |
Trade: Concrete Sealer
Contact sealworks all your concrete sealing and waterproof needs. just use au at end of website address
Trade: DUST FREE Media Blasting and Sandblasting
I do a lot of stamped concrete sealer removal with our wet abrasive blasting process.... hey it pays the bills.
![]() Stamped concrete sealer removal on walkway before ![]() Stamped concrete sealer removal on walkway after ![]() After stamped concrete was resealed ![]() Note how the sealer looks like paint after more than four coats ![]() Stamped concrete sealer removed from walkway ![]() After stamped concrete was resealed ![]() Note how the stamped concrete sealer failed and started chipping ![]() This is what it looked like with all sealer removed ![]() After stamped concrete was resealed
AtlanticGreenPro.com Surface Restoration Surface Coating Removal Metal | Concrete | Stone | Brick | Wood | Composites | All Sealed Surfaces NJ, DE, PA, NY CT and MD Facebook page: http://www.facebook.com/AtlanticGreenPro?v=wall Last edited by MasterBlaster; 07-15-2011 at 06:47 AM. |
This is another Stamped Concrete job we recently stripped the sealer from... note it was resealed before I was able to take the stripped surface photos... but it still turned out nice and looks brand new again.
![]() Stamped concrete sealer before we removed it. ![]() Stamped concrete resealed (note no photos of the surface stripped. ![]() Stamped concrete sealer before we removed it. ![]() Stamped concrete resealed (note no photos of the surface stripped. ![]() Stamped concrete sealer before we removed it. ![]() Stamped concrete resealed (note no photos of the surface stripped. ![]() Stamped concrete sealer before we removed it. ![]() Stamped concrete resealed (note no photos of the surface stripped. When resealed the stamped concrete looks as good as new.
AtlanticGreenPro.com Surface Restoration Surface Coating Removal Metal | Concrete | Stone | Brick | Wood | Composites | All Sealed Surfaces NJ, DE, PA, NY CT and MD Facebook page: http://www.facebook.com/AtlanticGreenPro?v=wall |
| Tags |
concrete sealer white ![]() |
| Advice - concrete Pool Deck coping | ejleonard | Masonry | 4 | 06-17-2008 05:18 PM |
| New Concrete Floor laid, cracking, and sealer Q's. | Knyte260 | Construction | 21 | 10-07-2007 12:25 AM |
| concrete sealer | kermmonk | Construction | 3 | 08-01-2007 07:26 AM |
