Concrete Popping?
Old 07-08-2010, 12:44 PM   #1
chawsome's Avatar
Trade: general trades
Concrete Popping?
Recently, I poured a driveway for a customer that after 4-5 months started to flake off or pop off on the top. I realize salt use in the winter would cause this, however the homeowner assured me he did not use any salt. Another contractor says the mix from the plant, probably the sand, was dirty. I have poured concrete for 15 years and never had this happen. Is there something I did to cause this problem, or is it dirty sand?
chawsome is offline
Old 07-08-2010, 02:23 PM   #2
painter213's Avatar
Trade: Coatings consultant and Inspector
Rewards Points: 1,334
Re: Concrete Popping?
Is it popping down to the stone? It could be caused by AAR - Pop out caused by Alkali-Aggergate Reactions. This is where the stone actually burst in two and causes a pop out in the concrete. Here is a better definition.
Alkali-aggregate reaction is a term mainly referring to a reaction which occurs over time in concrete between the highly alkaline cement paste and non-crystalline silicon dioxide, which is found in many common aggregates. This reaction can cause expansion of the altered aggregate, leading to spalling and loss of strength of the concrete.
NACE Certified Coatings Inspector Level III #7953
SSPC Protective Coatings Specialist #2014-529-139
babbott@abbottcoatinginspections.com
205-717-0292
painter213 is offline
Old 07-08-2010, 02:25 PM   #3
rselectric1's Avatar
Rewards Points: 574
Chawsome,
Please do an intro in the introduction section and put your location in your profile.
Thank you and welcome to CT.
rselectric1 is offline
Concrete Company delivered junk concrete. How best to pursue? marcomjl Concrete & Paving 47 06-03-2014 10:17 PM
Concrete with Fly Ash vs. Concrete without? cdkyle Concrete & Paving 19 07-28-2010 09:57 PM
Tire line in concrete after finishing. aydin_eng Flooring 34 03-09-2010 09:03 PM
4x4 posts in concrete vs. saddles Strongarm Decks & Fencing 20 08-31-2009 09:41 PM
concrete popping while troweling house bldr Construction 4 08-25-2006 08:03 PM
