Cold Patching
Old 04-10-2009, 02:42 PM   #1
pcdrifter's Avatar
Trade: general contracting,excavating,tree removal
Question
Cold Patching
I have a customer that had an underground tank removed several years ago, they paved over the area for parking but the area setteled. The area is about 10' by 18' and it needs filled in approx. 4", can cold patch be used for this if tamped with a plate tamper every 2"?
pcdrifter is offline
Old 04-21-2009, 07:29 AM   #2
Owner
Adasidewalk's Avatar
Trade: Concrete Construction
Re: Cold Patching
Cold patch will only fix it in the short term. The proper fix it hot mix and excavating the area to a good subbase. This may require some sort of gravel or stone under the asphalt.
All types of concrete and asphalt work
romanoconcrete.com
Adasidewalk is offline
Old 04-26-2009, 11:46 PM   #3
TERM101's Avatar
Trade: General Construction
Re: Cold Patching
Excavate the area to 10" below finish grade. Compact the subgrade nice and tight and add 8" of ABC stone. Compact the abc and overlay with 2" of I2 hot mix asphalt. If there is any driving or parking on top of this area (I assume there probably is not, but very well may be) I would go with 8" abc, 2" B25 binder, and 2" I2.
TERM101 is offline
How do you keep cold air out of a range hood? Mike(VA) HVAC 7 01-25-2009 05:16 PM
No cold air return. Wolfgang HVAC 5 01-13-2009 06:41 PM
very cold outside air from cold air return ?? slawek HVAC 3 12-24-2008 09:30 AM
cold air return on slab construction LeroyJnks HVAC 4 07-11-2008 04:08 PM
FDA to declare cold medicines too risky for babies, toddlers eagleandbaby Off Topic (Non Trade) 0 01-17-2008 09:36 AM
