Trade: Remodeling contractor
Getting Started With Sketchup
How do I post drawings?....thanks
Back in Maine Dubbin' Around Doin' good stuff ...... |
Re: Getting Started With Sketchup
you mean jpegs of drawings? or the actual file of the drawing? the actual drawing, I believe you have to .zip it first to post it. The jpeg you need either a small enough file to use the attachment method or you need to host the jpeg on another server.
It looks like both have a 200 kb limit. to zip it in xp (I'm assuming that's what you have) right click the file and select send to>compressed (zipped) folder In SketchUp, you use File>Export and select jpeg for your file format to save a jpeg of the view you have on your screen. When you get to the point of replying or posting to a thread, you hit the icon that looks like a paperclip
If you correct your mind, the rest of your life will fall into place ~Lao Tzu Custom Cabinetry - Portland, Cape Elizabeth, Scarborough, Kennebunkport, Yarmouth, Falmouth, Cumberland, Ogunquit, Maine Salmon Falls Cabinetry Last edited by KentWhitten; 02-22-2009 at 03:51 PM. |
Eater of sins.
Trade: Designer/Drafter Extrordinaire
Go to the "Export" option under the 'File' menu, then save the drawing (whats on the screen) as a jpg or jpeg file in whatever folder you want to.
When you are on the thread on ContractorTalk you want then go the "Post Reply" button, click the little icon for attachments, looks like a paper clip, browse to the file you saved then double click on the file. Back in the paper clip dbx that came up hit upload. Then close out of that. Post as you would normally and the pic will be included. Andy, |
Trying to upload scetchup drawing of a glass block in a block wall
Shoot
It's not letting me change the drawing to a jpeg file............
Trade: Carpentry / Fencing / Decks
I save mine as a PNG and upload
www.ParkerFenceandDeck.com |
Don't change the drawing, save the drawing. Use "File" in SketchUp, then "Export" then "2d graphic" it should pop right up to jpeg.
When you "Export" it will say "Export type" at the bottom of the window. Choose the type you would like to make the file and hit the Export key.
Holy cow it worked!!!!!!! I went to 2D image.
Thank you. This is an awesome forum. You people are so smart. You must be young.
I'm 41 and I'm young. And that doesn't look too bad there Tom
If you correct your mind, the rest of your life will fall into place ~Lao Tzu Custom Cabinetry - Portland, Cape Elizabeth, Scarborough, Kennebunkport, Yarmouth, Falmouth, Cumberland, Ogunquit, Maine Salmon Falls Cabinetry Last edited by KentWhitten; 02-28-2009 at 01:10 PM. |
Re: Getting Started With Sketchup![]() PUP ![]()
| Some amateur Sketchup Work | slowsol | Drafting & CAD Forum | 20 | 02-06-2009 07:35 PM |
| Sketchup practice. | Forry | Drafting & CAD Forum | 14 | 02-06-2009 02:47 PM |
| Sketchup dock rendering | casey344 | Drafting & CAD Forum | 16 | 12-26-2008 09:21 PM |
| Sketchup procedure | TDF | Decks & Fencing | 8 | 11-17-2008 09:21 AM |
| Sketchup VS Sketchup pro | RobertCDF | Technology | 6 | 05-06-2007 08:14 AM |
