Mark
Big Dock Job - Design Ideas
Attached are some preliminary drawings for a dock job we were asked to do. The customer has provided most of the design info, see first picture.
Any input appreciated, we used to build simple docks and things have really gotten complicated. Need some aesthetic and architectural criticism and/or suggestions. I have a 1200 square foot limitation and a 40k budget. The cupola's will match, I know I need more poles etc etc. I am just working on preliminary drawings to show them. After some input I will get into the finer details. ![]()
Casey |
Trade: Construction
Re: Big Dock Job - Design Ideas
That budgets going to be cutting a bit fine with it being that complex. Around here they charge about 20k for just a basic double dock with standard pitched roof. If you want a deck area instead on roof then it's even more.
They charge around 800-1000 a pole for pileing for timber poles around here and from looking at your plans your gonna need a good 35-40 of them. Band/Header boards are about $1500-$2000 a single dock so your looking at around $6000-$7000 for just them let alone the expensive of the boats lifts and PWC lifts or floats. Looks like a very nice dock though if they are willing to spend some more money to get it like your plan. Last edited by BCConstruction; 08-27-2009 at 06:24 PM. |
Mod / ArchiBuilder
I like the design, but for $40k!!! No Way!
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
Mark
Maybe I am being naive but simple math has me at $33/sf. They have the jet-ski and boat lifts so they are not part of this 40k.
The only complicated build is the octagon gazebo, we have never built one. Otherwise it is a pretty simply build. He is willing to sacrifice fancy decking material and use pressure treated. We get $150 per pole plus the cost of the piling for setting a pole with our pile driver and it takes roughly 30 minutes to set one including fetching it and placing it under the hammer. He is not quite sure if he likes the gable roof coming out of both sides of the main roof, even though it was his idea. Any ideas how I can tie the two roof together without it looking like a series of roof systems?
Casey |
#5 | |
Trade: Construction
Re: Big Dock Job - Design IdeasQuote:
Mod / ArchiBuilder
Casey, can you show us some dimensions?
#1 stunner
I hope you're not showing them those renderings on a 40k job, i'd turn you down on a heart beat: but then again I graduated with an architectural degree so my standards for renderings are higher: especially on decent size job.
Trade: Construction
All the dock plans i see around here are like his first picture and customers have no problems with them so his other renderings are a vast improvement to what you see around here. No point in getting too carried away as it is just a boat dock also.
#9 | |
Mark
How about suggesting some changes to the design? Is it the design itself or the way I am presenting it that you feel brings out my shortcomings? Admittedly we can build better than design so feel free to make suggestions. Casey
Casey |
You did what??
Re: Big Dock Job - Design Ideas |
| The Following User Says Thank You to J F For This Useful Post: | XanadooLTD (10-14-2009) |
Garage and Storage Plus
Trade: Garage Enhancement
Huh? Is 40K a lot of money these days? There's maybe 8,000 dollars of profit in that job if things go well--for that amount of profit, I am more than willing to let the customer use his or her imagination.
#12 | ||
#1 stunner
My birth mother??? or my wife??. ![]() Quote:
Yes 40k is alot of money, I don't have that in my checking account. These days in my area you're lucky to get 15k jobs unless you're building new houses.
#13 | |
#1 stunner
Yes that may be true but it's a competitive market now, if this guy can show his clients top notch drawings and do great work then he is going to gain more customers: what a great way to set himself away from others. |
#14 | |
Trade: Construction
Is that bit in red a joke or are you serious? Just in case you are the door is on a gable end. It wont allow for a full height door and i guess it's maybe just a storage area. Looks just about the right size to me. Also i can tell you now that his drawings are way better than what anyone else will prob submit so he should be fine. Like OP says most will just submit a quick pencil drawing. Last edited by BCConstruction; 09-01-2009 at 08:13 AM. |
#15 | |
#1 stunner
Also, should and being certain is to different things, this guy can do a few little things and make him look a lot more professional. |
Trade: Carpentry/aspiring CGC
you need some serious help with that one...start with a basic framing sketch, then elaborate on it and evolve the interior to the customers needs
where are you located?
Mark
Here are some dimensions on this job. Good or bad the gazebo had to go. We went way over our 1200 allowable square feet.
Casey |
#18 |
Trade: contractor
I assumed the door was to a storage space.
#19 |
#1 stunner
#20 |
Trade: Build, Remodel, Roofing, Siding etc...
Just a couple things I would consider. Since all the specs aren't given, these things may be non-issues. If it were my house, I would do something a little different with the square deck. Maybe add a small 12" bump on the water side of it, with 45 degree return angles. You could also clip the two end corners and 45 them as well. Every designer/Architect I've met hates square objects. Something needs to be done where the deck meets the roof. You don't want the HO or HO's kids to be able to access the roof that easily from the deck. Go with the largest spiral stairs their budget and taste allows, since this is their only access. Spiral stairs are a real pain in the arse to carry things up and down, so the bigger the better. One other thing, is this a tidal water body? If so, make sure there is clearance for the boat at high tide plus a few extra feet.
| Practical GREEN ideas that don't cost much, part 1. | wackman | General Discussion | 24 | 03-15-2010 07:52 PM |
| Home Design Software - i.e. Punch Home & Landscape Design | Panzer5 | Technology | 19 | 12-29-2008 11:09 PM |
| Free Download: Advanced Energy Design Guide | Ed the Roofer | Roofing | 0 | 02-09-2008 09:01 PM |
| need design ideas for shower | HomeSolutions | Ceramic & Stone Tile | 9 | 01-17-2008 08:10 PM |
| Got some design ideas for tile wainscoting? | Mike Finley | Ceramic & Stone Tile | 2 | 05-09-2006 10:05 AM |
