Best Way To Span 32', Unsupported
Old 11-13-2017, 09:05 PM   #21
AustinDB's Avatar
Rewards Points: 464
Re: Best Way To Span 32', Unsupported
regarding the design criteria, I've been approached by homeowners that said they wanted a particular pitch/style roof to match with the original structure. sometimes you have to provide some options that look better or are more feasible. I hate adding on something that will overpower the original structure and look downright bad.
steel would be great for what you are doing. a lumber yard may be able to design a truss package for you. I use to use Wyoming Millwork in Delaware, they included the engineering with the purchase price. they have expanded into MD by now, not sure, but their PE may be licensed in MD so it may work out for you.
AustinDB is offline
Old 11-14-2017, 03:21 AM   #22
MeanWeen's Avatar
Trade: City worker
Rewards Points: 24
If steel is an option, look up a steel building supplier near you on the inter web. Phone them, tell them what ya after. You won’t need standing seam roofing, get an interior lining for ceiling. In 1 or 2 days an email will show up with a drawing and a price. Buy it. Not sure about where you are but up here might be 10% or so more then the wood. Your engineering will be done. Should be able to attach to slab on grade(save on concrete work) and you should be bout 5 days labour inc. concrete work....yw
MeanWeen is offline
Joist Span on Decks Rizz861 Framing 6 06-11-2015 04:57 PM
Need help on span dimension. 7CB7 General Discussion 7 05-20-2013 08:01 PM
Is this entry span too wide? Californiadecks Decks & Fencing 15 08-22-2012 11:56 PM
proper subfloor AustinDB Tiling 35 05-26-2012 02:16 PM
Floor Joist Span BuriedHammer Framing 16 12-30-2008 09:03 PM
